Can someone please explain the Bar setups for FI?
Old 07-19-2009, 09:41 PM
98RedBird's Avatar
Default Can someone please explain the Bar setups for FI?
I have been searching and trying to figure it out and have vague answers but I was wondering if you guys could explain what the different Bar setups are when you go FI and delete the MAF?
Thanks
Old 07-19-2009, 09:53 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
1 bar is standard atmospheric pressure. if your engine has zero vacuum, and zero boost, it is operating at 1 bar.
2 bar is twice the standard atmospheric pressure. 2 bar is 14.5psi above ambient pressure, or 14.5 pounds of "boost"
3 bar is triple the atmospheric pressure, or about 29psi above ambient pressure.
gauge pressure (psig) is what is referred to as "boost" because its a measurement over ambient pressure. absolute pressure (psia) is pressure above a complete vacuum. a naturally aspirated engine operates between 0-1bar since it will never get into boost. therefore, factory N/A cars only have a 1 bar map
1 bar = 14.5psia = 0psig
2bar = 29psia = 14.5psig
3bar = 43.5psia = 29psig
psia is absolute pressure, psig is gauge pressure. unless otherwise noted, 99.9% of the time people say "psi" they mean psig
ok, i hope this helps.. i don't know how many other ways to explain this
*edit* it should be noted that 1 bar is by definition 100kPa (14.5psi) while a normal more accurate "standard" atmosphere at sea level is closer to 14.7psi(a) or 101.3kPa or 101.3bar. also, it should be noted that not all 2 or 3 bar MAP sensors are exactly 200kPa or 300kPa respectively. you should check the specs on the specific sensor you are using for tuning purposes.
Old 07-19-2009, 10:09 PM
98RedBird's Avatar
Okay, thanks man, I'm pretty sure I get it now. So, if you're not going to be pushing above 14.5 lbs of boost then would you just want to go with a 2 bar map?
But I guess that doesn't make sense to me because the guys that procharge their cars don't need to upgrade to the 2 bar MAP correct?
Maybe I don't get it...
Old 07-19-2009, 11:51 PM
BigRich954RR's Avatar
For around 15 psi i would do a 2.5 bar
Old 07-20-2009, 01:37 AM
98RedBird's Avatar
So how do the guys who run boosted cars on stock motors get away with not running an aftermarket MAP?
Old 07-20-2009, 02:15 AM
kdavis's Avatar
wow this helped me alot. thanks
Old 07-20-2009, 04:20 AM
You mean when they stay MAF tune ?
Old 07-20-2009, 05:34 AM
98RedBird's Avatar
Yes, is the MAF making up the difference? So the 2 and 3 bar map sensor tunes are if you're running speed density?
Old 07-20-2009, 07:09 AM
ChevyChad's Avatar
You really need to do some more searching man. This question has been answered many times. Basically, on a stock MAP sensor, ofcourse, the MAP sensor will be maxed out. The tune adds fuel based on the amount of air coming in thru the MAF. It can do this for up to 500-550rwhp, then the MAF will get maxed out as well. Once that happens, the tune is then adding fuel based on RPM alone since the MAP and MAF are both maxed out. That is pretty much a bandaid way to go about things. Once you max your MAF out, you'd be better off switching to a SD tune so that it adds fuel based on boost rather than RPM like it would a maxed out MAF tune. This is where the 2 and 3 bar MAPs come into play.
Old 07-20-2009, 08:08 AM
No Juice's Avatar
Well, said, which reminds me I need to get a 2bar
Old 07-20-2009, 01:16 PM
98RedBird's Avatar
Well as we all know, the search on this site is sometimes nothing short of spectacular...
Regardless, awesome man, thanks for the explanation. You cleared it up perfectly for me.
Old 07-20-2009, 01:58 PM
airforcemanss's Avatar
this was helpful thanks chad
Old 07-20-2009, 03:33 PM
ChevyChad's Avatar
glad i could help guys.. we really need more stickies here in the FI forum to clear up so many of these questions because you are right, the search is hard sometimes when you don't know the keywords to search for.
Old 07-20-2009, 03:45 PM
98RedBird's Avatar
X2 on the stickies!!
Lol, even when you have the keyword perfect the search brings back some pretty "WTF!" results most of the time...
Old 07-20-2009, 03:51 PM
Big_Bird_WS6's Avatar
ok hp has a 2.5 bar tune for a certain computer.
can i run that computer in my f-body?
or does BS3 have a 2.5 bar?
