What is the effect of being to the left of the surge line in lower rpm?
So I've been using the consumption chart for a 370ci LS1 and compressor maps on www.forcedinductions.com
From plotting points what is the effect of being to the left of the surge line at low rpm(3000) then moving in toward the center island higher in the rpm?
Even if it does happen you usually transition though it pretty quick and it's a non issue.
Since you have a 3000+ stall i'd start plotting from there up since you will not make any boost below that point unless you are on a two step.
