oil smoke advice
oil smoke advice
need some opinions. have a tti kit with bb 76mm turbo. getting oil smoke out the exhaust side of turbo (know it is exhaust side as it will do it without intake tract connected) when i get out of throttle under boost or when shifting under boost. i hate the drain back set up and feel that may be part of problem (50-60lbs of oil pressure). goes in front of pan but is a 90 up into the pan with very little drop in line. put restricter in feed line in and i think that has helped some. think it is drain related or seals gone in turbo? hate to take turbo back off as it is no fun to insall (even on lift). could go scavenger pump if that would cure. just looking for some advice before i start tearing it apart. any thoughts would be appreciated.
thanks,
eddie
thanks,
eddie
Options are limited.
Use a smaller restrictor. Sometimes it takes 3 or 4 tries to find the right size but when it's done, it's right for that oil weight/pressure.
Use a bigger drain line.
Use a lighter oil to reduce pressure just a bit. What are you running right now?
Scavenger pump solutions are out there but it's money and time as well.
Rick
Rick
As far as restrictors, don't run restrictors to solve your problem... Run a restrictor ONLY if to adequately feed the right amount of oil for that specific turbo requires it.
If the problem is, solely, draining oil from a turbo, then you need a draining solution, not a restrictor. As mentioned, reclocking the turbo or running a scavenger pump are the things you should be thinking of.
My turbo sits pretty low, and it didn't drain at all... I got smoke (oil into the dp), and oil in the intake side. Ran a scavenger pump, and now the problem is gone, PLUS I still know the turbo is getting the right amount of oil.
oil issue
i am currently running 10/30 mobile 1. this is my 7th turbo project, but first on an fbody and never really had this problem before. i know not everyone is on board with the oil restrictor but i have never had trouble in the past (always the first time though) with using one on a bb turbo and they usually take care of the issue. however the drain back on the TTI kit leaves much to be desired in my book. every other project i have done has had a much greater drop on the line, not only in angle but distance too. just not alot of other options with the placement of the turbo. hate to drop the pan, but it looks like it is either that to get a better drain location or go with a scavenger system at this point.
i have the same problem with my kit my turbo sits so low that the drain is level w the bottom of the oil pan so i get a little drain back when i let off i hate it and wish i could find a solution its an innovative turbo kit
drain
same with me, i hate it and cant stand to drive the car with the oil issue. it has sat in front of my shop for 2 months and not moved. in that time i have built up another turbo project (87 Mk vii with 302) s0 guess it is time to re address the f body. it would not be so bad if it were not so hard to access the oil pan on these things.
YUP... lol
I'd neglect it, too, myself...
I've been putting off redoing the oil pan gasket (small leak) on my stock, black Trans Am for, oh, about a year now.
thanks,
eddie
thanks,
eddie
http://www.mcmaster.com/#46425k21/=2ufjna
about the same oil pressure as you are, between 65-70 under boost and with rpm's coming up. think i am going to bite the bullet and try a scavenge pump. to be honest with you i do not see how oil can drain at all with the stock tti set up. it was always i big worry of mine when i installed the kit. i am also running a catch can with both valve covers and pcv to intake side of turbo with check valve and oil separator (never any oil in the separator, a little condensation of water sometimes).
i do not think it will have to be very big. thinking about cutting down an old ac dryer from a chev. truck and using it. i would think that something that held around a quart +- would be more than enough, considering some people are draining straight into the pump and having success. ordered the pump yesterday so i will start at least getting a general idea of the lay out this weekend.
I use the Mocal pump, and when its on it works great, I had some problems with my signal wire for the relay though, but I will solve that when the turbo moves up front in my car in a few weeks.
And for catch can size I think its more important to get something that will allow oil to freely flow out of the turbo more than how much oil it can hold. I'll try to round up a pic I saw a while back that had a great idea.
Edit: This thread, not meaning to ***** the guys thread out but the first 2 pics you can see the device im talking about .. look at the turbo drain
