Heres the 383 quote to hold my STS help me pick it apart
I have an sts with t67 and fmic. here is the estimate I recieved from local shop can you help me pick it apart as far as parts, also is labor reasonable.
Parts
Wiseco 3.903 -15cc Dish Pistons w/ File to Fit Rings 770.00T
K1 Technology 6.125 Connecting Rods 550.00T
ARP Main Studs 230.00T
Durabond Cam Bearings 30.00T
Clevite H Series Main Bearings 110.00T
Clevite H Series Rod Bearings 65.00T
GM Press in Oil Plug, Oil Dumbell Plug 16.00T
K1 Technology 4" stroke Crankshaft 780.00T
Labor
Dissassemble Short Block 125.00
Hot Tank Shortblock 115.00
Toque Plate Hone Cylinders 225.00
Align Hone 185.00
Balance Rotating Assembly 185.00
Assemble Shortblock 400.00
Deck Block Square 150.00
FL & EXC County Sales Tax 191.33
$4,127.33
Parts
Labor
Align Hone 185.00
$4,127.33
You can go way cheaper with a 370 iron and make just as much power. You will save on the crank,maching,disassembly,hottank,hone and other things. A lq9 from sdpc will run u 800 and some change rods and pistonswill be around 500-700 range in all if you shop you could save 2k on the build. There are numerous 370 in the 800 hp range. Hell my motor is a lq9 punch out lol but i spent 8k on it because i wanted some serious ****.
Well you can cut costs by doing everything minus the machine work yourself that is if you have the tools and the knowledge. And as for parts, go with the stuff you know works, and look around for deals.
yeh im going to save the 125 for disassembly ill do that. and Ill ask if I do all the machine work will they cut the assembly down to 200. and looking at buying parts from tsp with all the upgrades they still look like the best price
Id be at like 3400 buyin the assembly from tsp and having the machine shop do the work if I can get them to budge a little. The tsp assembled are 3700 plus shipping.
wow, I really need to raise my prices. I did zombiess complete engine for about 3500$, but that was the long block with heads/cam/oil pump etc....
If budget is a questin I d do a iron 370 too.
Jeremy tuned mine when I was in Vegas, now Im living in FL. Ended up having machine shop start work.. They saved me a few bucks and Im looking at ordering the Callies crank and rods. Total Seal napier rings and going from there. Machine shop/ builder will take care of the bearings. And got a good lead on a tuner.. I tried to get you to do some work on my car John but you were a busy man.. And from what I hear about your building skills I would raise your price too. Im just on my own in a new town and a forged 383 for about $3400 doesnt sound to bad and I think it will work well with the 67 turbo
