Custom Cam Spec Idea's?
Seems things have been switched from 91MM to a F-1R due to the fact my car has been sitting enough so were speeding up the process and getting something complete.
So cam specs.
Motor: 408ci
Heads: PP Stage 3 035 Heads. Flow 320 235 @ .600
Intake: Victor Jr Intake
Fuel: 96lb Injector
Trans: TH400 Tranny with 3800 Stall
Gear: 3.07 gear
Power Plant: ProCharger F-1R
Goals: 1100+rwhp will be manily track car. With the option of driving it to a local a event if I want.
Any more specs you guru's think I might need to list let me know
So cam specs.
Motor: 408ci
Fuel: 96lb Injector
Gear: 3.07 gear
LS1Tech Sponsor
Figuring you have a big open exhaust with 2" primaries and dual 3.5" exhaust.For 1100rwhp through that setup, the blower at max rpm,you will need a cam roughly a 252/268 with .600-.640 lift on a 113-115.Expect it to rev out to atleast 7500rpm. Hard to say since we don't know the heads.
Better heads will be a adder later. Currents are Patiort Peformance Stage 3 LQ9 035's
Current Cam I have now that I am selling is 231/226 601/591 115 lsa
For FI no I would not think so. I am using what I have and will make upgrades later when I have more $$$ to work with. These are not too far off base with say a ETP 237CC head as they flow 335 235 @.600 and what I have flows 320 235 @.600
As for fuel I am unsure its good to 1000rwhp+ I am working with what I have.
