How and where to mount IAT
Old 08-06-2009, 12:50 AM
67Firebird455's Avatar
Default How and where to mount IAT
Just curious if you use a stock iat sensor or something threaded on a boosted application. I didn't use one on my 99 turbo TA (dangerous, I know), and would like to get this setup situated, just need some insight. Thanks again guys!
Tony
Old 08-06-2009, 07:42 AM
Super Slow SS's Avatar
I used the stock one and the stock grommet in the charge pipe just before the TB on mine, dont think I have a good pic, so far no problems with it blowing out.
Old 08-06-2009, 07:49 AM
Tally TransAm's Avatar
i did some digging on this last night cause im in the knick knack stage of my turbo build now
the threaded sensor is from a 91 GMC syclone and is part number WT382P or GM# 25036751 and uses a 3/8" NPT bung
Old 08-06-2009, 07:50 AM
dudeman's Avatar
i drilled and tapped the intake right behind the throttle body and used the cyclone sensor.
Old 08-06-2009, 11:31 AM
Right on, that will work! That's all I needed to know! Same type of clip and everything?
Old 08-06-2009, 11:46 AM
RooRnZ28's Avatar
I am using this same sensor... no risk of it popping out!
Old 08-06-2009, 11:58 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I'm using a threaded IAT sensor in mine in the pipe just before the 90° silicone bend that goes into my TB.
https://ls1tech.com/forums/11950864-post81.html
Old 08-06-2009, 12:00 PM
Man that looks great. Run it! =) Thanks for the help fellas!
Old 08-07-2009, 02:54 PM
SRZ
SRZ's Avatar
Mounted mine before the TB like stk.
Quick Reply: How and where to mount IAT
