ls2 and borg warner
Old 08-06-2009, 03:32 PM
Big_Bird_WS6's Avatar
Default ls2 and borg warner
what is a good borg warner size for a stock ls2. say 8psi. but yet if i ever build bottom end it will also let me run 12-16 psi also.
thanks
Old 08-06-2009, 03:33 PM
LS1Tech Sponsor
hellbents10's Avatar
372 will get you too 800fwhp with ease and run good on a stock engine.
Old 08-07-2009, 01:02 PM
LS1TECH Sponsor
DrTurbo's Avatar
Correct we sell the BWS400-72 and 75mm versions for those apps. Like TJ said, they will work very well.
Old 08-08-2009, 05:29 PM
so like a t3 or t4 flange?
what would a good a/r be?
Old 08-08-2009, 10:51 PM
B18CYA's Avatar
S400's are t6 flanged but are great bang for the buck just a little on the big side.
Old 08-08-2009, 11:23 PM
myls-won's Avatar
Your web site says that there is a t4 housing option, what kind of restriction does that put on say the 72mm? Also what size DP does the t4 housing accommodate?
Old 08-09-2009, 09:09 AM
4SFEDZ's Avatar
my ltx 385 just put down 670 @14 thru a th400 and a s60! that would be close to 800 with a m6! and this was in 100+ degree tx weather!
Old 08-10-2009, 09:52 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yes we carry the T4 option units as well. As far as restriction.....typically will limit the map by 2-10% based on the cubes of the motor. To many variables to say it effects it by X amount.
Quick Reply: ls2 and borg warner
