cobalt map sensor questions
Old 08-06-2009, 03:34 PM
speedcrazy2's Avatar
Default cobalt map sensor questions
im am going to run the cobalt sensor like everyone recommends but will it work with my 98 pcm or do i need to upgrade to one that is capable of 3 bar sensing
planning on running 14 to 16 psi. so i dont really need the 3 bar capability
im sure i can just wing it if my boost is a little higher than 14 lbs.
Old 08-07-2009, 08:44 AM
fitz98ta's Avatar
I had the cobalt sensor on my 98 computer with no problems. You just have to get HP Tuners 2 bar custom OS. With the 98 computer you can't run 3 bar or I wouldn't have switched to an 02 pcm and harness
Quick Reply: cobalt map sensor questions
