Any ProCharger A4 guys having issues with A/C at idle?
Old 08-06-2009, 06:48 PM
'Trust''s Avatar
Default Any ProCharger A4 guys having issues with A/C at idle?
My A/C will simply not blow cold at idle, it is fine at anything above 1500 RPM's, but at idle it is warm, like the compressor just isn't on. I've already replaced the compressor and I don't know what else to do. Anybody have any ideas? I'm assuming a 3.4 on the blower is some strain on the accessories and something is killing the compressor under strain, I just don't know what to look for? Mechanical Gurus, Tuning Gurus, any help would rock!
DISCLAIMER: I posted this in FI because I think it is related to the blower and strain.
Old 08-06-2009, 07:31 PM
blue00ZZleeper's Avatar
Mine is a bitch at idle as well...I stay away from using it unless I'm cruising for extended times lol...my idle will roll and it doesnt blow very cold like yours...
Old 08-06-2009, 08:20 PM
black01_WS6's Avatar
do you have a underdrive pully on the car? My N/A car does the same thing but it is from my 25% underdrive pulley. I know most don't put a underdrive pulley on with a procharger, but they do sell them and could be your problem.
Old 08-06-2009, 09:13 PM
'Trust''s Avatar
Nah, 8" A/C pulley on the crank, stock on the compressor.
Old 08-06-2009, 10:19 PM
D-Webz's Avatar
Mine does the same thing in traffic, highway its fine. I have an M6, tuner tried raising the idle a bit but still have problems with it.
Old 08-06-2009, 10:23 PM
'Trust''s Avatar
Hmm, hopefully someone will chime in, I'm stumped, and it seems to be mostly an FI/Supercharger issue. I was thinking of finding and overdrive A/C pulley for the crank, but I really don't want to pull the balancer.
Old 08-07-2009, 07:13 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Thats why I just sold my whole kit. I got tired of being tired of chasing issues...
Old 08-07-2009, 09:26 PM
WAHUSKER's Avatar
I'd bet it's from the cam/stall/blower combo. All the surging you get at idle drives the PCM nuts. It only stands to reason that either the PCM disables the AC at idle, or it just says F this, I aint got enough coolant flowing on a regular basis. Not sure how sophisticated these computer cars are for stuff like that, but they could easily write that code.
Sorry, I tore my AC unit out so I can't go compare & look at stuff.
Old 08-08-2009, 12:12 AM
03supercobra's Avatar
Most AC's don't work well at rpm's below 1500/2000k. With more rpm the freon is at the correct pressure to cool.
Old 08-08-2009, 05:49 AM
Dan Stewart's Avatar
The system in our cars is a VDOT, the computer doesn't look at flow. The compressor changes displacement based on high side pressure (using hydraulics....a pilot valve).
If the underhood temps are pretty high and rpm is pretty low, then the compressor will probably run at max displacement and still not meet the high side pressure needs.
A set of manifold gauges will tell much.
Old 08-08-2009, 04:24 PM
'Trust''s Avatar
I don't knkow what manifold gauges are, any idea how I'd trouble shoot?
Old 08-08-2009, 04:34 PM
Its just a set of gauges that show you suction and discharge pressure, they looks the same as gauges for your home AC ect. It is a way to check if you have a proper charge on your system. I am sure whoever installed your compressor and charged the system has a set.
Old 08-10-2009, 12:51 AM
D-Webz's Avatar
My ac killed my car twice today, was trying to make a light and braked real hard. The second time I was stopped at a stop sign I just rolled up and stopped real slow. IDK WTF but it sucks and I'm tired of it.
Old 08-10-2009, 01:03 AM
TS6
TS6's Avatar
It has nothing to do with the blower. Most likely its because of the lack of airflow through the condensor. Have you verified that the compressor is running during the rpm ranges you say its blowing warm? If not, it may be low on refrigerant. If it is, its most likely airflow, probably because the ATI fan setup isn't that good.
Old 08-10-2009, 04:41 AM
EPP
EPP's Avatar
The first thing (if you haven't already) I would do is to do a really good job of cleaning the condensor, as they tend to get a build up of bugs, road debris, etc on our cars. This can make a very dramatic difference in the cooling efficiency. Bob
Old 08-17-2009, 12:22 AM
'Trust''s Avatar
I removed the condenser, cleaned it out completely at a high pressure car wash, degreased it, and there is also a pusher fan on it now to help keep the motor cool, no change. Any other input would rock! Thanks for the help thus far.
Quick Reply: Any ProCharger A4 guys having issues with A/C at idle?
