DIY (homemade) METH kit??? + some meth questions....
Old 08-06-2009, 09:50 PM
Restricted User
1BAD_LS1's Avatar
Default DIY (homemade) METH kit??? + some meth questions....
Well as some of you know i killed my 70000 mile ls1..... lol Now im broke and cant afford a forged motor so i am going to use a pullout 5.3l and throw some boost at it till i can afford to build a forged 370.
I am going from an sts kit to a front mount GT70 with FMIC setup and want to use meth as my "safety net".....
I was wondering what all is needed to build my own meth kit?
Thinking about using -20* washer fluid.....
How much meth is actually used on a street car? I am at 4000ft above sea level and it gets 100*+ during the summer when i drive the car.... about 7000 miles a year and alot of those miles are hard WOT lol.
Thanks for the help guys!!!!!!!
Blaine
Old 08-06-2009, 09:51 PM
shtnfrds's Avatar
I wonder how many hits this thread has on the federal drug task force...
Old 08-06-2009, 10:00 PM
Restricted User
1BAD_LS1's Avatar
Probably alot in just the last 10 minutes.... lmao!
Old 08-06-2009, 10:06 PM
Restricted User
1BAD_LS1's Avatar
O ya forgot to mention that i work at Simplot (a fertilizer company) so i have access to alot of different pumps and spray nozzles and hoses and ect......
Hoping i can do it relatively cheap because this is an extreme budget build.... Will only have about $1200 in it pre-meth!
Old 08-06-2009, 10:11 PM
gametech's Avatar
Blaine
If you only use it as a "safety net", then you don't need it at all and it costs you $0.
Old 08-06-2009, 10:13 PM
trans2000am's Avatar
you can prolly build a kit pretty cheap, my only concern would be the safety side of it(warning lightes,low pressure ect)
Old 08-06-2009, 10:19 PM
'Trust''s Avatar
Get a diaphragm pump (go to Alkycontrols site to see which they modify), wire it into a WOT switch and you'll probably be ok (assuming you make at least 4psi at WOT). Not as good as a progressive controller, but better than by button.
Old 08-06-2009, 10:24 PM
Restricted User
1BAD_LS1's Avatar
true.... safety is important....
What is the best kit for the money to use on my 5.3 with 10-12psi? (Doing a Parish8 budget 5.3l turbo build)
How about this?
http://cgi.ebay.com/ebaymotors/alcoh...Q5fAccessories
Thanks,
Blaine
Old 08-06-2009, 10:30 PM
Restricted User
1BAD_LS1's Avatar
I have the stuff off my sts kit but i think the pressure switch is only 1 psi.... because i thought about using it, but 1 psi wouldn't work.....
Thinking it may be easier to just spend the $200 coolingmist kit above......
Old 08-06-2009, 10:37 PM
'Trust''s Avatar
Probably, the Snow kit is priced well too. You want to make sure you're moving enough air so the vaporized water/meth distributes properly.
Old 08-08-2009, 09:45 PM
Restricted User
1BAD_LS1's Avatar
so how often will i have to fill my washer fluid tank???? I put about 14-30 WOT passes a month on the street....
Basically how much washer fluid will my meth kit use on a pass or how many passes can i get on a tank? wondering how much washer fluid i need to buy lmao.
What is the best brand washfluid is the best to use?
Thanks!
Old 08-08-2009, 11:57 PM
ak95ta's Avatar
Thanks!
I use a -40*, brand is Turbo Power, hehe. They sell it up here at the local Schucks/Orieleys.
Old 08-09-2009, 10:03 AM
Texas_WS6's Avatar
Can you use 100% methanol? If you had access to 100% methanol can you make your own mixture? What do you mix it with?
Old 08-09-2009, 10:39 AM
nastychevelle's Avatar
http://www.turbomirage.com/water.html
Old 08-09-2009, 03:59 PM
'Trust''s Avatar
You can make 116 octane with 100% pure WATER, the only benefit to methanol is that is an actual fuel so if you were to have say a 11.5 A/F, if you inject 100% meth and don't change the tune, you will make the mixture more rich, this is why when people are pushing their injectors sometimes they'll spray meth.
Old 08-10-2009, 06:20 PM
blazin's Avatar
i used a devils own kit on the ta i built. install was cake
Old 08-11-2009, 07:36 PM
Restricted User
1BAD_LS1's Avatar
so i have another question:
I can control when the meth kicks in by pressure correct? So what if i want it to spray less or more depending on how much boost i am pushing? or will i be fine with meth just kicking in at 6psi to 12-15psi?
Kinda trying to keep this as budget as possible considering the 5.3L im installing will only have like $6-$800 in it. lol
Old 08-11-2009, 08:50 PM
Super Slow SS's Avatar
Progressive kits are avail. but they get up in cost a bit.
Old 08-13-2009, 09:32 PM
Restricted User
1BAD_LS1's Avatar
OK but do you guys think it would be worth the extra cash for me to buy a progressive kit?
Im thinking i should just buy the baseline kit.... but i want some opinions.
Old 08-13-2009, 09:43 PM
Dan Stewart's Avatar
You want budget, eh?
Get some tubing, a hobbs pressure switch, a 12-volt solenoid valve (heck, you can get creative: fuel injector, n2o solenoid, whatever), a washer fluid pump (make sure it creates more pressure than the amount of boost you are running), a spray nozzle, and something to regulate flow (needle valve works great), some wire, and a bottle.
There you go.
Water/meth injection isn't rocket science. I used a setup just like that on my old GTP and worked like a champ. I would fill the reservoir everytime I filled the gas tank.
The following users liked this post:
JoshuaGrooms83 (12-13-2019)
Quick Reply: DIY (homemade) METH kit??? + some meth questions....
