The Great Debate-- What Compression for a daily driven stroked 383 with STS??
Well I cant seem to find a definate answer so seeking the pros. Here is the setup im in the middle of buying. Keep in mind this is a daily driver with STS t67..
2001 Ws6 ls1
Callies 4.00" Compstar crank and rods, arp throughout
EPP Forced induction cam
Cam specs: Dur @ .050 232 int 240 exh Lift .595 int .608 exh Lobe Sep115.0
Stock but polished heads
Chromoly pushrods
dual gold valve springs
#42 injectors
walbro 255
STS t67 with FMIC
Here is the debate... The pistons...
Should I go with the Wiseco -15cc dished and be at 9.6-9.7:1?
Or
Should I go with the Wiseco -32cc dished and be at 8.5:1?
Its killing me to make this decision and Id like to order tommorrow. What kind of numbers do you think this setup will make also on good tune.
2001 Ws6 ls1
Chromoly pushrods
#42 injectors
walbro 255
STS t67 with FMIC
Or
The -15 will be fine unless your gonna run huge boost or only have access to crap fuel.
The turbo is gonna be a bit small for a 383 and i would upgrade the injectors to 60s, your gonna max the 42s pretty quick with FI
