What are you guys doing for fuel pressure in your 600+ vehicles?
Old 08-16-2009, 06:42 PM
vipvegas's Avatar
Default What are you guys doing for fuel pressure in your 600+ vehicles?
I have a 255 walbro in place now and installing 79# racetronix injectors. Worried about fuel pressure. Is there a dual walbro setup. What do you guys recommend on the lighter side of the wallet. Have a feeling my new 383 is going to need a little more..
Old 08-16-2009, 06:54 PM
'Trust''s Avatar
Dual walbros is good for 1000HP reliably I'd say. I think Mighty Mouse has a write up on it.
conan's Avatar
Give lonnie a call, very happy with his dual intank set up. http://www.lonniesperformance.com/
Old 08-16-2009, 07:08 PM
vipvegas's Avatar
looked at lonnies only if I had the cash. Tried searching can someone direct me to a writeup. If TRUST is correct adding another walbro would be perfect just want to know how, wiring etc..
Old 08-16-2009, 07:18 PM
MosesMcgregor's Avatar
racetronix single pump, MSD BAP speed inc. rails and 60# injectors. Planning on adding a return line. Its workin' fine so far but i'm about at the limit of this setup.
Old 08-16-2009, 08:45 PM
vipvegas's Avatar
Im going to do a dual intake walbro 255 setup since Ive already got one pump. Just got to figure out the wiring. Think Im going to run the one pump relay to trigger off the 1psi switch for the sts, its easy to access and wont be needed now that Im deleting the pcv using a catch can.. What you think
Old 08-16-2009, 09:15 PM
LS1Silverado05's Avatar
I think it sounds like a plan... Twin Walbros should do the trick!
Old 08-16-2009, 10:08 PM
conan's Avatar
https://ls1tech.com/forums/fueling-i...ick-cheap.html
Old 08-16-2009, 10:41 PM
vipvegas's Avatar
just got a new pump for GSS340 for 66 bucks. on the way be here in 6-9 days and Ill update on the install
Old 08-16-2009, 11:35 PM
Killer deal! PM me with your source??
Old 08-17-2009, 12:22 AM
blue00ZZleeper's Avatar
Ditto on that pm ...I'd like 2 please lol
Old 08-17-2009, 10:58 AM
needaz28's Avatar
I need more fuel as well. Ill take a pm if u don't mind.
Old 08-17-2009, 11:03 AM
Zombie's Avatar
Two pumps should no issues going 1000 rwhp on gasoline. I'm 800ish rwhp in e85 and a completely stock style fuel system setup and twin pumps.
Old 08-17-2009, 11:13 AM
'Trust''s Avatar
2x walbros, FAST rails, boost referenced reg. and supporting injectors will be good for a lot of power, I'm still on the stock feed with 773RWHP thru an auto, I'm probably maxing out the stock feed, but just to give you an idea.
What size feed are you using? Just curious.
Old 08-17-2009, 01:10 PM
Zombie's Avatar
Stock. My only fuel system mods are dual pumps and 95lb/hr injectors.
Old 08-17-2009, 02:21 PM
vipvegas's Avatar
Im going dual walbros, stock feed and rails, 79# injectors got the miss listed on a auction site for $175. new shipped and there Racetronix.
Old 08-17-2009, 03:11 PM
LS1RedZ's Avatar
The Lonnies dual walbro kit is NICE if you wanna spend the coin.
Old 08-18-2009, 08:49 PM
vipvegas's Avatar
So I got my new 79# injectors, and dual 255's, running stock fuel lines and rail.. Do I need to worry about pressure or adding a regulator?? Or just drop in pumps and install new injectors tune and go???
Old 09-05-2009, 07:09 PM
Restricted User
1BAD_LS1's Avatar
I wanna know this also.... for my new build.
Old 09-05-2009, 07:29 PM
MY99TAWS6's Avatar
Adjustable reg is nice if you want to go lower or higher than factory fuel pressure. And being boost referenced is also nice. I say get one they are pretty reasonable in price.
I would also get some bigger rails and upgrade the factory feed and return but that could come later on.
I also have lonnies twin setup. No complaints with it. Lonnie is great to deal with.
Quick Reply: What are you guys doing for fuel pressure in your 600+ vehicles?
