Procharger pully swap ???
Old 08-18-2009, 02:22 PM
conan's Avatar
Default Procharger pully swap ???
Well as usual it's never enough power, so I'm going from a 3.7" pully to a 3.4" pully. My question is because the blower will be spinning faster all through the rpm range will this also produce more power in the lower rpms as well as peak? So the entire power curve will go up?
Also after some searching it seems like the best way to get the pully off the blower is to hold the pully with a strap wrench and use a inpact gun to remove the bolt, then a small 3 jaw puller to remove the pully from the head unit? Are the threads of the blower pully bolt righty tighty lefty loosey or are they reverse threaded?
Thanks guys... Chris
Old 08-18-2009, 03:05 PM
Ryan33187's Avatar
Sound exactly like I did it... if I remember right they are normal thread righty tighty lefty loosey. If you have trouble getting the new pulley on put it in your oven for about 5 minutes at 315 degrees it will slide right on after that.
Old 08-18-2009, 03:11 PM
conan's Avatar
Cool thanks, I use the "baking" method on my crank pully all the time. Works great.
Also any of you guys use blue lock tite on the pully bolt?
Old 08-18-2009, 03:12 PM
Ryan33187's Avatar
It called for red in the instructions.
Old 08-18-2009, 03:16 PM
conan's Avatar
Thanks man!
Old 08-18-2009, 03:45 PM
'Trust''s Avatar
Is your pulley not keyed? Mine is and it slides right off after the bolt is off. And I did the exact same thing, the car sees more air all through the RPM band, and of course you'll make more boost so you will need a retune.
Old 08-18-2009, 04:20 PM
conan's Avatar
When I bought the procharger from SDCE the 8 rib 3.7" was already on the head unit. So I have never taken one off before.
Thanks for the info, thats what I'm looking for is more power in lower rpm's as well as peak. A retune is already scheduled.
Thanks again, chris
Old 08-19-2009, 04:58 AM
EPP
EPP's Avatar
Thanks again, chris
Wow, 7000 ft! EEK....... Bob
Old 08-19-2009, 07:30 AM
conan's Avatar
Not an easy place to make power up here where the planes fly. It is nice to have 3 ski resorts all with in a 10 min drive, so the love-hate relationship continues.
Old 08-19-2009, 10:10 AM
allthrotle's Avatar
Have you had the chance to take your combo to the track yet? You and I have similiar set ups, I was just curious cause im almost at 5000ft elevation.
Old 08-19-2009, 10:16 AM
conan's Avatar
I have not yet, I'm about $1000 short from a 12 bolt rear end. I'm hoping to have enough saved before the snow starts flying here to get some times. The 1/4 mile track down in salt lake city is around 5,000 ft, so it will be interesting.
Quick Reply: Procharger pully swap ???
