20psi on 6.0L???
Old 08-22-2009, 03:24 PM
dudeman's Avatar
Default 20psi on 6.0L???
what do you guys think about 20lbs of boost on a forged 6.0 with 317 heads, arp head studs and gm mls head gaskets. is this a bad idea?
Old 08-22-2009, 03:27 PM
sabastian458's Avatar
aluminum block? that kinda psi I would use the iron block.
Old 08-22-2009, 03:33 PM
HUNTER02SS's Avatar
You will be fine with either block. I would call Virgina speed----->>>>
and talk with them. They have the 4 bolt head setup hauling azz!
Old 08-22-2009, 03:47 PM
dudeman's Avatar
i will be using an iron 6.0.
Old 08-22-2009, 05:28 PM
OUTLAWZ RACING's Avatar
thats pretty much what I have 6.0l iron and 317 heads and about 18 psi 813 hp I also run arp studs not a hint of pushing water.
Old 08-22-2009, 05:35 PM
dudeman's Avatar
what headgasket do you use? can you give more details on that 813hp? turbo, cam, stock heads? i am going for 700whp with stock heads and a epp blower cam and lots of boost!
Old 08-22-2009, 05:46 PM
I used Gm mls gaskets and a light coat of copper seal.
Pm sent.
Old 08-22-2009, 06:49 PM
TurboAv's Avatar
What about the Felpro gaskets?
Old 08-22-2009, 06:59 PM
3timeracin's Avatar
I have had great sucess with the SCE titan with the built in fire ring on my stuff. They cost $250 a set, But I have a friend with them on a 6.0 with 317 heads a PT88 and 22psi over 200 passes 1500 street miles and 0 water.
Old 08-22-2009, 07:10 PM
dudeman's Avatar
thats impressive!
can you pm me a link to them?
Old 08-22-2009, 07:37 PM
dudeman's Avatar
what about head studs? is arp good enough?
Old 08-22-2009, 10:13 PM
cjg454ss's Avatar
i have a 6.0 block, i run 20+psi with a pt88, do yourself a favor and get the block oringed. its 400 bucks or so and will take care of your head leak issues for a long time. i did and never push a drop. dont even bother with expensive gaskets. mls factory gaskets with an oring in the block. its cheap and works. the Grand national guys have been doing it for years.
Quick Reply: 20psi on 6.0L???
