Size hose and what size fitting for oil return with turbo?
Old 08-23-2009, 05:18 PM
vipvegas's Avatar
Default Size hose and what size fitting for oil return with turbo?
What size hose and what kind of fitting are you using for the oil return at the pan with your turbo? want to run same hose supplied with sts to oil pan to eliminate going with the return through the oil fill.
Quick Reply: Size hose and what size fitting for oil return with turbo?
