What size spring for Tial BOV?
Old 08-28-2009, 01:24 PM
XtremeDime's Avatar
Default What size spring for Tial BOV?
I see there several different size springs for the Tial BOV, anyone know which one to use?
Old 08-28-2009, 01:32 PM
veee8's Avatar
Depends how much vacuum at idle your cam pulls.
Old 08-28-2009, 04:38 PM
XtremeDime's Avatar
Stock cam, Im not sure how much.
Old 08-28-2009, 05:14 PM
TiAL's Avatar
you need to know this
Old 08-28-2009, 09:11 PM
pwrtrip75's Avatar
what difference does it make? I just threw my BOV valve on the way i got it. What would it do w/ the wrong spring?
Old 08-28-2009, 10:55 PM
LS1Silverado05's Avatar
Umm not operate properly...
Old 08-29-2009, 12:30 AM
vipvegas's Avatar
definately not good could over boost..
Old 08-29-2009, 03:37 PM
pwrtrip75's Avatar
BOV has nothing to do with regulating boost to make it overboost.
Old 09-01-2009, 11:37 PM
barnat's Avatar
I always thought that some guys run a BOV as a safty feature just incase of a stuck wastegate or over boost condition so as not to damage the engine or blow a head gasket ???Thats why you can buy predetermined (higher springs) for them to change out, just above your current boost setting.Lets say your running 10PSI and wanted a safty in there for your build,youde put 12 PSi springs in there I know ive heard of guys doing this !
Old 09-02-2009, 07:17 AM
veee8's Avatar
The different springs are for different manifold VACUUM levels, not boost pressures. Boost holds the bov shut until it is removed, like when the throttle is lifted, then it pops off.
Maybe if you never attached the reference line to the top of the bov, but the springs are very light for fast response in a bov, nothing like a wastegate.
Old 09-14-2009, 01:36 AM
KILLER-LS1's Avatar
hey well my cam pulls around 12-15 in/hg im assuming i either need the 7 or 9 psi spring?
Old 09-14-2009, 10:47 AM
Formerly 4mulaJoe
LS1x2's Avatar
They have a guide on their website. Just reference your vacuum. If you run a blower use the 3psi spring.
Old 09-14-2009, 11:26 AM
TiAL's Avatar
-7 would be good for you
if you get a Q you would want the -8
Quick Reply: What size spring for Tial BOV?
