boosted g8 at 5psi, can't tune out knock.
just got done putting twin 60mm turbos on my g8. base spring pressure is 5psi.
timing is set at 11.5deg at peek tq and 15deg at 6000rpm. a/f ratio in the mid 11's. iat's at 120max. coolant temp at 180. fuel is 91octane from bp
we were seeing knock retard from it mid 2nd gear on.
we tried more fuel, put the wideband into the high 10's and that didn't help. put the fuel at 12/1 and it got much worse.
last thing we tried was to put timing at a flat 10deg at wot. car showed no knock retard at all but it lost power.
is 11.5deg-15deg too much timing for the motor at 5psi? i wouldn't think so but maybe.
thinking about a meth kit.
its the fuel my car on 91 sucks it wants to knock all the time but when i use my meth no knock at all and thats on 17degs for hp and 22degs for tq
but i have not tryed race gas yet to see if that helps any
or its a bullshit knock sensor thats bad, and thats picking up nosie from something else just some ideas. but you guys look pretty smart so i dont know LOL
Restricted User
You running an intercooler? What kind of charge temps are you seeing? Have you tried running race gas to see if it goes away? Is it knocking everywhere on wot or always in one spot? Screen shot of knock retard histo log of a pass? You sure it's kr and not just pulling timing?
9 Second Truck Club
99% sure it is real knock retard since it completely goes away if i pull timing back to 10deg. never have heard it. but it looks real on the scan tool. always come in sometime mid to top 2nd gear and gets worse in 3rd.
cant post up pic of scan, right now my hptuners box it out for repairs so i was using a buddys box and laptop.
it is intercooled. iat's varried but when i tried to not let the car heat soak they started at 120deg and actualy fell to 118 during the run. only 5psi.
injectors have no head room so i cant mess with e85 right now.
no vvt but it does have dod.
i feel like we tried a lot of things and we are probably at the limit of the fuel we were using. might be crap gas or just all that 91 is good for.
LS1Tech Sponsor
Those cars have a lot of false knock, you will have to try race gas to verify. Just tuned a procharged one at 7psi the other day. It had headers and exhaust, it made 499whp through the auto. This was with about 15-17 degrees of timing, AFR was 11.5:1 and IAT's of about 125.
Timing seems real good too, I wonder if its vvt related?
one thing I just thought of....when I was fixing cranks....there was up to 5 degrees of error on the reluctors when installed on the cranks. It could be really more timing then your seeing......I doubt it too....but might belong on the lis of consideration.
A cold air, and meth...might fix it. Hey are you a dealer for meth? I just got a new dealer relationship....and tried a kit on the van...and for the money it works pretty good.
Restricted User
Restrictive exhaust will cause detonation. My old setup was an LS2 408 with true dual 3". I used to daily drive the car and the true duals with the Borla XR1's were a bit loud. I had a friend that works at an exhaust shop make some removable baffles for it that quieted the car way down. Unfortunately, due to the restriction, I had to keep the RPM's under 5K or I would get horrible knock with the baffles on.
Why not just listen for knock instead of relying on the knock sensors, which can pick up all sorts of noises ??
The human ear is very good at filtering. Hook up a set of cheapy "det cans" and listen to see if there is any detonation.
Plugs - NGK BR7EF (Stock 3346)
Octane - 91 is terrible anyway you look at it. If thats all you have available, stick with the blue gas stations. (Chevron, Fina)
With an efficient engine, I run 14 degrees on pump, c16, torco, whatever.
I would be willing to bet that the octane is the source of your problem.
-W
-W
It certainly worth quickly removing the whole system and running open pipes just to check.
91 isnt great for boost, but what you describe sounds pretty extreme.
that is at 11.5deg at 4800 and 15deg at 6000rpm.
then with 10deg it is completely clean.
doesn't that seem real?
