Fitting for fuel pressure gauge
Old 08-31-2009, 09:14 PM
Super Slow SS's Avatar
Question Fitting for fuel pressure gauge
Does anyone know what fitting(s) I will need to install my AEM fuel pressure gauge? I would assume I just need something to go on the end of the fuel rail to push in the needle valve and have a female port to screw the pressure gauge into but I dont know much about those type fittings.
Old 08-31-2009, 10:20 PM
Hi-Po's Avatar
Well, I can tell you that a -6 AN female fitting is too large. I was told -6, its not. Must be -4 AN fitting. I bought a Adaptor the SHOULD have screwed onto the fuel rail, has a 1/8 NPT port, then bought a cap for the other end. Is it -4 AN to connect to the fuel rail?
Old 08-31-2009, 10:45 PM
LS1Silverado05's Avatar
You need a female -4AN to 1/8 NPT There are a few styles of fitting to do it depending on if you need to flow through the fitting or just go right into the gauge only...
I dont think there are any that will push in the valve for you, I removed mine..
Old 08-31-2009, 11:00 PM
Hi-Po's Avatar
Dont know why I was told -6. Waste of money.
Old 09-01-2009, 12:43 AM
Avengeance's Avatar
I noticed you are in the process of building your setup.... I suggest this.... first off remove the schrader valve from the fuel rail end.
-4AN female to -6AN male adapter... then into a -6AN female to -6AN female then to the Aeromotive boost ref adjustable FPR, which has a return line to the tank.
Old 09-01-2009, 06:37 AM
Fireball's Avatar
x2
just use a tire valve core remover to remove your valve.
Old 09-01-2009, 10:34 AM
Thanks for the information! I have a valve core remover and will be taking this out and ordering the AN adapter.
EDIT:: I cant seem to find a female to female -4an to 1/8 npt .. links?
Old 09-01-2009, 10:40 AM
Nasty N8's Avatar
I have the AN fittings you need in stock $13.50
Old 09-01-2009, 01:32 PM
Parts ordered, Thanks for the Help!
Old 09-01-2009, 02:04 PM
JAX04's Avatar
be sure to take that valve out slowley as it will spray some fuel on you ask me how i know. LMAO!!
Old 10-20-2009, 08:13 AM
C_Rules's Avatar
anybody know if the schrader valve on an lt1 f body would also be -4AN?
Old 10-20-2009, 08:20 AM
sujomatt's Avatar
Is there a link to this fitting/adapter? Thanks
Old 10-20-2009, 09:31 AM
C_Rules's Avatar
acutally i think you guys are doing something completely different and removing the schradervalve off completely and replacing it with the an fitting. not sure if that would work on the lt1 style. but if anyone knows please let me know.
Old 10-21-2009, 12:53 PM
C_Rules's Avatar
i found out what would work on my lt1. earls 361-100201 with a cap for the male thread.
Quick Reply: Fitting for fuel pressure gauge
