Boost cam for my budget 5.3....
Old 09-03-2009, 05:25 PM
Restricted User
1BAD_LS1's Avatar
Default Boost cam for my budget 5.3....
Well i am looking for a cam for my budget boost 5.3 project.... I was going to just get a ZO6 cam because it has proven to make great power with the boost 5.3's...
I came across a cam on here with these specs: 231/226 601/591 115
Do you think this would be to much cam for the little 5.3 or do you think its just right?
I think this cam would work great.... but im no cam expert lol.
This will be my setup: Pullout 5.3, 317 heads, PRC Dual Springs, 3600 stall, 3.70 gears, Master Power T70 .96AR Truck manifold setup.
I know there isn't anything better than a custom spec'd cam but this is a BUDGET build.
Thanks guys!
Blaine
Old 09-03-2009, 05:46 PM
nastychevelle's Avatar
thats to much cam if you ask me
talk to Shawn at VA speed he has a nice turbo cam that would work very well...
i also know parish gained 100rwhp at 8psi by switching to an 02 z06 cam over the stock 5.3 cam
Old 09-03-2009, 05:56 PM
Restricted User
1BAD_LS1's Avatar
ya i seen parish's dyno charts for the ZO6 cam swap.... think i might just go that route. Its been proven many times to work great in the 5.3
Since my budget is so tight i think it will be the cheapest route to go also.
Old 09-03-2009, 06:04 PM
Restricted User
1BAD_LS1's Avatar
Im really just looking for a cam to help me meet my 550-600hp goal.... dont think the stock cam is gonna get me there... lol
Old 09-03-2009, 08:30 PM
the z06 cam had parish in the 600+ range
Old 09-03-2009, 08:45 PM
firefightergib's Avatar
z06 cam is the way to go for a budget!
Old 09-03-2009, 09:06 PM
Restricted User
1BAD_LS1's Avatar
JUST FOUND AN 02 ZO6 cam!!! thanks guys!
Old 09-03-2009, 09:48 PM
built408's Avatar
I would just run the 5.3 heads with the z06 cam. 317 heads will drop the compression too low IMO.
Old 09-03-2009, 10:00 PM
sujomatt's Avatar
whats the size difference between 5.3L vs 5.7L?
Old 09-03-2009, 10:32 PM
LS1Tech Sponsor
hellbents10's Avatar
We have been past 850whp with the LS6.
Old 09-03-2009, 11:03 PM
Restricted User
1BAD_LS1's Avatar
cubes, most 5.3 are iron blocks, accessories
Old 09-03-2009, 11:05 PM
Restricted User
1BAD_LS1's Avatar
nice.... I won't come close, i will be pushing it trying to get 550-600 lol
Old 09-03-2009, 11:18 PM
Restricted User
1BAD_LS1's Avatar
I got the 317'a because a lot of guys are making good power with them.
it should be 8.7-8.9 comp
I think you can make more power with less comp and more boost than more comp less boost... correct?
gonna run 12-15 psi at 12-15 timming with meth and fmic
should make my goal.... I hope
Old 09-04-2009, 05:28 AM
9 Second Truck Club
stock48's Avatar
The high comp will make more power with race fuel and timing. In my opinion it's best to choose a CR that will allow you to run within 4~8* of what the combo would run for timing NA, with enough boost to keep the turbo in it's effeciency range, on the fuel that you plan on using.
Old 09-04-2009, 07:31 AM
71 chevy's Avatar
how much low end does the z06 cam lose to the stock cam?
Old 09-04-2009, 04:52 PM
67Firebird455's Avatar
Shoot, hardly any, look at the freakin LSA, still very little overlap, just a bit more duration. I picked one up for my 4.8 that I also have a set of fresh #317's for. Plan to run 15psi though also, run it.
Old 09-04-2009, 08:41 PM
71 chevy's Avatar
is there a power curve out there for this? of course 100rwhp would be sweet , but I would like to see where it would overtake the stock cam for torque.
I saw a 5.3 build that made 140hp over the stock heads and cam but the stock heads and cam were the king in torque and hp till about 3000 rpms
Old 09-06-2009, 03:17 AM
Restricted User
1BAD_LS1's Avatar
I have a vig 3600 stall.... not to worried about under 3000rpm
Old 09-06-2009, 12:42 PM
airforcemanss's Avatar
do you have to tune an ls6 cam swap? btw, do you guys know how far in the rpm range the ls6 cam goes up too?
Old 09-06-2009, 12:56 PM
dudeman's Avatar
comp should be around 9.3:1 on a 5.3 with 317 heads. you should be able to get 15lbs w/o meth and you should be able to run more timing than that also.
Quick Reply: Boost cam for my budget 5.3....
