can i buy procharger mounting hardware?
This ****** **** NEVER ends!!!
So after drilling and tapping the block i go to finally mock up the head unit and now i dont have the ****** mounting hardware. I need the 3 spacers to space it away from the alternator and the 2 long threaded rods etc. Basically everything to mount the J-bracket. I sent a PM to Bob@EPP just waiting to hear back. In the meantime does anyone know if i can even buy them and for a ballpark price??
Its just threaded rod, rod couplings, and some bolts and washers. Easy to find at the home depot or alike.
or
http://www.exoticperformanceplus.com...html?item=1472
or
or
or
The 8 rib mounting stuff is definitely different. It's longer and pushes the J-bracket a little further out from the block. Not sure if this is relevant to you but the 8 rib crank pulley mounts differently than the 6 rib. I had to buy an ATI damper and then source my own bolts to mount the A/C pulley (from ATI), the ATI damper, and the Procharger 8 rib crank pulley all together. The bolts from both Procharger and ATI are not long enough for cars that want to keep A/C.
i have everything, it all came with the kit its just that my dumbass lost all the hardware. I have all the pullies, brackets etc just no way to mount the ****. And actually i have one spacer off the alternator bracket. I see they list them part by part with p/n's. Wonder if i can just order only what i need. Guyss i wont know till i talk to bob, but worst comes to worse i buy the entire 8 rib kit for $60 and be done with it. To me $60 is well worth it for no headachs!!!
