Sts turbo
Sts turbo
What does everyone think of STS turbo kits? The only reason I would consider one would be because its Smog-legal, streetable and you have all the power unlike N/A cars where one little upgrade like cam or headers and you cant even drive it anywhere.
If any of you out there have tried or still have STS turbo kits on your 2000-2002 camaro f-bodies, please give Me feedback and advice on this:
-if I should get STS turbos or not?
-if yes, please tell Me how big of a turbo (mm) should I go with?
-list of supporting mods
-WHAT CAM SPECS & HEADS
Please Im very close to purchasing one but I dont want to make BIG Mistake.
Any help will be appreciated, thanks
Call and talk to freddy over at sts. I ordered mine last week w/ a t-67 upgrade/meth/hp tuners/and elect boost controller. They actually take the time to explain everything. The new kits are revised with dual tailpipes, and better ground clearence. Also comes with FMIC. The base kit comes with 42# injectors and predator tuner. I upped to 60# and hp tuners. As far as customer service they are great people to work with.
Good Luck!!!!
Good Luck!!!!
Listen to my STS on the Dyno. This was the 2nd pull, at the end I made 600 RWHP with less then 7 lbs of boost, on a VERY conservative tune. I drive this car everyday, NO PROBLEMS AT ALL. STS has been great to me.
http://www.youtube.com/watch?v=P-nc24dOHmk
thats 500 rwhp. dont get his hopes up!
ive have dealt with sts in a fashion in which most would not. i would agree that they are great with customer service and are very helpful with tech support. i see nothing wrong with using the sts style "kits", but im a fan of turbos staying where the heat is.
only issue would be a little lag, but ****, its not all that damn bad.
whoa.... since when and who the hell "on headers" can't drive their car around, it gives you about 20 HP and changes nothing else, no shift points no idle nothign. there are way more cammed cars running around daily than there are turbo cars that's for sure. ( it's a lot cheaper) an extreme cam effects drivablity, but you can put down well into the 400's and still have a very driveable car.
If you don't know how to work on a turbo car you probably shouldn't bother unless you have deep pockets.
and that was 530 ... not 600. unless you have another dyno pull vid.. .. 7 PSI isn't 600 HP on a LS1 car.
my buddies running an intercooled STS pushing over 630 to the wheels in Vegas with his SS. feel free to contact Garth at Leading Edge Performance for me details....
http://www.youtube.com/watch?v=DR4c6qz80GA
I love how well, everyone reads. THAT video made 530, the FINAL PULL made 600.
LEP: Guarantied 500rear wheel + , top quality work, a shop i would almost eat off the floor of & fantastic customer service. youtube search " Leading Edge Performance "
& call Garth (owner) to get more in depth details and a phone call is next to free
702-375-4999
STAGE-3
LS1 STS Turbo kit
42LB Green top Injectors
Autometer
Boost gauge
Wide band
Dual a-pillar pod
Custom LEP 4"intercooler (FMIC) & piping (powdercoated)
255lph Walbro/racetronix w/hotwire kit
Tial blow off valve
LEP custom turbo camshaft
LEP dual valve springs
with titanium retainers
LEP 0.80 C/M pushrods
200' DEI exhaust wrap
GT-67- or 70 Turbo upgrade
LEP ported/polished stock manifolds
Fuel pump hot wire kit
T-bolt clamp upgrade
LEP custom mods to the cold side piping
Installed & tuned
$8,500
a few other goodies
702-375-4999
STAGE-3
LS1 STS Turbo kit
Autometer
Boost gauge
Wide band
Dual a-pillar pod
Tial blow off valve
Installed & tuned
$8,500
a few other goodies
I actualy sold my car to a friend here localy and he tuned it on pump gas and 12lbs of boost with the maf not speed density and made 750 rwhp with a safe tune.Needless to say thats with a 408 and an 88mm turbo outback so you can make power with a rearmount but Ill b the first to tell you It takes time and alot of trial and error to get the set-up wright.Now on speed density and e-85 it will be over 850 rwhp hes thinking without a problem and then start adding the boost
