Do I need to swap wastegate springs?
Im running whatever came as the stock spring with the sts kit. But now have a 383 stroker with TC78. Im running the sts dual boost controller. Do I need to switch springs to achieve 10-12 pounds on the low side and 15-16 on high side mode? I believe with my old 67 in place I was hitting like 6-8 on low mode and at switch 12.
I believe it is yellow? whatever comes with the stock sts kit.. I was going to grab the spring one size bigger and carry with me incase I need it once I get there for the tune.
http://www.tialmedia.com/documents/w3_tial_44_sp.pdf
It is a tial 38mm supplied by sts. Guess I will remove spring tommorrow and see whats in there. I know when I had the car running with a T67 in place I was holding and running 7-8 psi max on the low setting/on spring. And 12 with the high ending setting/ running through sts dual controller. So I want to hit like 10 on the low setting so Im thinking I got to up the spring. Maybe to the Large red. So I get a little more boost on the low setting and will be capable of more on the high setting.
