Obx wastegates
Old 09-07-2009, 01:11 AM
TX RED's Avatar
Default Obx wastegates
Any body running this brand ....leaves to put on flame suit ....
There cheap just like cxracing intercoolers, should I try them out
Old 09-07-2009, 01:22 AM
OUTLAWZ RACING's Avatar
I had a obx intercooler that's it. i have never heard of their wastegates. I would just get a jgs or tial. You dont want that gate to **** up hell 50 dollars can cost u 5k lol.
Old 09-07-2009, 04:11 PM
TX RED's Avatar
Tttt for the moring
Old 09-07-2009, 04:14 PM
7 Second Club
Phil99vette's Avatar
They work great until they fail and you overboost and blow your motor.
Old 09-07-2009, 04:27 PM
camarokid94's Avatar
just thinkin out loud here guys but what about a hobs switch that kills the motor when it hits XX amount of boost. set if to 18 if you run 15 or something like that just a thought. ( by no means am i sayin run a cheap wastegate and use this to cover your *** im just thinkin out loud)
Old 09-07-2009, 07:16 PM
subarubill96's Avatar
a cheap wastegate belongs in the trash, not on your turbo setup. a cheap
A2A intercooler might be ineffecient but its not going to directly pop your engine if it fails. a cheap wastegate, well at least you might get to see how much boost it takes before a piston/ con rod/ bearing wipe out the whole show
Old 09-07-2009, 08:17 PM
TurboAv's Avatar
Just keep an eye out in the for sale section and ebay for quality parts. I picked up two brand new JGS 50mm wastegates for $225 from ebay.
Old 09-07-2009, 09:38 PM
mobileheath's Avatar
why not try it....set your fuel and ignition to 0 in your tune just above the max boost level you want to reach....if it overboosts it wont roast the motor
Old 09-07-2009, 10:18 PM
TX RED's Avatar
what size should I bee looking for will a 38mm take care of 6-10 psi
Old 09-07-2009, 10:33 PM
I run a 44 mm jgs on a 76 trim turbo. I think the bigger the turbo and the amount of boost you will need a huge gate. But a 38 mm tial will work just fine, I ran a tial on my 76 at 7 psi with no issue. I chang over to the jgs because it was smaller in size.
Old 09-07-2009, 10:51 PM
frcefed98's Avatar
quite a few guys on turbomustangs.com run em with good results...take it for what it is....I run a TiAL 44mm WG
Old 09-08-2009, 02:22 PM
TX RED's Avatar
I guess tial it is
Old 09-09-2009, 10:10 AM
TiAL's Avatar
a 38mm gate will not hold 6-10 psi on a 5.7 unless the A/R is overly huge
Old 09-09-2009, 10:37 AM
Why? I thought it boiled down to the turbo size and amount of boost
Im not a expert or trying to be a dick just courious.
Old 09-09-2009, 11:30 AM
05TurboCGM's Avatar
Because Tial 38s suck ***...go turbosmart and you'll be happier
Old 09-09-2009, 11:31 AM
sr71's Avatar
lower boost levels require bypassing more exhaust around the turbine to keep it slowed down. that is why you need a bigger gate to maintain lower boost levels.
Old 09-09-2009, 12:55 PM
TiAL's Avatar
this is the answer
Old 09-09-2009, 01:49 PM
this is the answer
Oh dam make sense Thanks bro.
Old 09-09-2009, 04:58 PM
TX RED's Avatar
So 44mm then
Old 09-09-2009, 05:00 PM
Originally Posted by TX RED
So 44mm then
I think so lol!!!
Quick Reply: Obx wastegates
