6.0L Iron + o-rings?
Old 09-09-2009, 03:24 PM
101mmSBC's Avatar
Default 6.0L Iron + o-rings?
I've done some research and have gotten some decent information. Just a few extra questions. I'm looking at doing an o-ring block, but not grove the heads. Is there anything different between doing o-rings on the stock 6.0L block compared to a sbc? Should you use the factory MLS gaskets? Copper? Graphite? Any addition prep needed? Thanks for the input guys.
Old 09-09-2009, 03:25 PM
knappbunch's Avatar
check with shawn at Virginia Speed
Old 09-09-2009, 08:58 PM
cjg454ss's Avatar
i have my 6.0 block oringing, ive ran mid 20s boost wise. no water pushing at all. i run just mls gaskets. stock 6.0 heads also
Old 09-09-2009, 09:19 PM
1320's Avatar
what wire? studs? 85 lbs?
Old 09-09-2009, 10:55 PM
camarokid94's Avatar
what ever happened to those" pyrimid (ps) rings from over in like sweeden or where ever. sounded pretty legit.
Old 09-10-2009, 07:19 PM
z28mccrory's Avatar
I revived that thread a week ago and no one had anything to add. Also curious.
Old 09-11-2009, 12:29 PM
valiant65's Avatar
Andreas dropped a valve into cylinder so the legendary budget engine is broken. Anyway, The Pyramidrings kept the seal to the end. There is a LSX-build coming next...
Video:
http://www.youtube.com/watch?v=y2jeViRTC3E
Story in swedish (there's pics also)
http://www.pure-pf.com/phpBB2/viewto...=asc&start=608
Old 09-11-2009, 12:39 PM
TT-TECH Veteran
Inspector12's Avatar
Yeah they were $400 for a set of the rings and gaskets. You still have to get the block and heads machined still, but looks like a good alternative if you can get someone to install them correctly especially if they have never installed something of that nature.
Old 09-11-2009, 02:53 PM
valiant65's Avatar
Still they do not need the heads be machined at all, only the top of bores will need a step machined, so that rings become a part of bore and deck. The sharp edge on top of ring will penetrate into head when head is torqued down. I have info from another source that this technique will work on iron heads too.
Quick Reply: 6.0L Iron + o-rings?
