building boost options
Old 09-09-2009, 07:38 PM
98transguy's Avatar
Default building boost options
I need to figure what the best option for me to build boost off the line is. (383ci ls1 with s91 turbo)Should i go with a dual rear caliper setup to build boost or do the upgrades on my 4l80e to get a trans brake put in?As of right now the cheper option is the dual rear caliper setup.And people with dual rear caliper setup how much boost have u built off the line?Thanks guys
Modifications in sig
Old 09-09-2009, 08:51 PM
cjg454ss's Avatar
get a 2 step, once you get on the 2 step it will build boost, i can get 15psi on mine on the brake though with my 2 step
Old 09-10-2009, 08:10 AM
98transguy's Avatar
i have a 2 step built into my BS3 problem was my brakes using my line lock couldnt hold long enough for the 2 step to build any boost
Old 09-10-2009, 09:12 AM
cablebandit's Avatar
tbrake is best bet
Old 09-10-2009, 05:17 PM
theblur98ss's Avatar
Were you able to build any boost at all? What did it run?
Quick Reply: building boost options
