Has anyone moved the cruise control module?
Old 09-10-2009, 08:02 PM
BadgeZ28's Avatar
Default Has anyone moved the cruise control module?
I want to make a horizontal shot from the supercharger inlet to the driver's side panel covering the area were the fog lights are on a F-body. Problem is the cruise control module is mounted in the way. Has anyone had success relocating this module? Thanks
Old 09-10-2009, 08:25 PM
Tzion_ben_Arthur's Avatar
I relocated mine in the trash
Old 09-10-2009, 08:44 PM
kkslds's Avatar
yea. i did. procharger kits come with a bracket to do it.
Old 09-10-2009, 09:26 PM
98Camarod's Avatar
Someone bought mine, it's in Canada
Did you're abs inop light come on after that?
Old 09-10-2009, 10:24 PM
TT-TECH Veteran
Inspector12's Avatar
It didn't do anything to the ABS light is just keeps the traction control light lit saying it is off just like when you turn it off almost everytime etc...
Old 09-10-2009, 10:26 PM
98Camarod's Avatar
I don't have traction control....
Old 09-11-2009, 12:44 AM
BadgeZ28's Avatar
I guess the next step is to find that bracket. Thanks for the info.
Old 09-11-2009, 02:27 AM
deadmanTA's Avatar
I moved mine back and up alittle enough to clear the IC pipe
Old 09-11-2009, 10:23 AM
BadgeZ28's Avatar
Deadman, After looking at the route of the cable I am wondering if there is enough slack to rotate the unit toward the driver's side fender 90%?
Old 09-11-2009, 05:57 PM
same here
Old 09-11-2009, 06:34 PM
98Camarod's Avatar
It's actually my Brake light that comes on, not the abs inop light
Old 09-11-2009, 08:14 PM
stevied916's Avatar
I just got a piece of aluminum and bent a 90 degree bend and there was my new cruise bracket. About $3
Old 09-11-2009, 09:19 PM
WS6HUMMER's Avatar
That happens when you run 2 different size tires. It happened to me whe I put 27's on the back with the 165's on the front.
Old 09-12-2009, 06:35 AM
98Camarod's Avatar
That's true, but before I took the cruise control off with my z06 rims/tires it was fine. Then I took it off and now its on. The abs inop is on because I took the abs off the rear, that comes on as soon as the car is started. The Brake light comes on after a few minutes of driving.
I ran two different size wheels before and after you went over 50 mph the abs inop and Brake light would come on.
Quick Reply: Has anyone moved the cruise control module?
