TC78 or PTE78 for LS2?
Old 09-11-2009, 02:32 PM
Snyper's Avatar
Default TC78 or PTE78 for LS2?
Im going to be ordering my turbo soon and was looking for opinions. Im ditching the nitrous setup for a turbo this year in my 350z. Im trying to decide which turbo I want to go with. Space is a concern but can be worked around if needed. Is the TC78 too small for the LS2? I plan on keeping the engine size the same with just rods/pistons when I build it. I hear a lot of good things about the TC78 I just fear it might be too small for my setup. I plan on taking the engine to 6500rpms max. For the first part of next year the kit will be run on a stock motor to make sure all the bugs are sorted out. Cam will be 224/224-ish. This is a 99% street car with the occasional trip to the track. I don't want a turbo that has instant spool(I actually enjoy the lag) and then dies out up top. Which one would you guys go with? And any opinions. Ill be doing the C6 manifolds with cross over setup. Also..does anyone happen to have a side by side comparison of the two turbos? Thanks.
Old 09-11-2009, 02:44 PM
LS1Tech Sponsor
hellbents10's Avatar
It will not be too small for a stock cube ls2. It will carry you to 800whp with out trouble.
Old 09-11-2009, 05:19 PM
Johnv's Avatar
TC 78 with 1.15 AR exhaust houseing
Old 09-11-2009, 06:53 PM
Snyper's Avatar
What would the spool time be like with that in comparison to the .96?
Old 09-11-2009, 07:10 PM
Snyper's Avatar
Anyone have a side by side of the PTE78 and TC78?
Old 09-12-2009, 01:32 AM
Johnv's Avatar
A .96 spools super quick on a 346 so i don't see a 1.15ar being a problem on a 364 LS2 and will give you more top end potential.
If your tight for space the TC78 wins hands down, but prob won't have quite the same ultimate power potential.
Old 09-12-2009, 02:31 AM
black98ws6ta's Avatar
PTE is more expensive, will make more power, spool alittle slower and is alittle bit larger. Both carry a one year warranty, Turbonetics unit comes with a polished compressor.
Old 09-12-2009, 08:26 AM
LS1TECH Sponsor
DrTurbo's Avatar
The TC78 is tough to beat. With a 1.15A/R housing it rocks on the top end and still spools like a magnacharger...lol. We sell tons of them to many LSX based folks.....they love them. Several on here have made some SERIOUS power when pushed. Most of these guys are street drivers though, and an honest 600rwhp is MORE then a handful on the street with any tire short of a full blown slick. The PTE is a great unit as well and uses a little larger turbine wheel, but the compressor wheel is the same as the TC's.
Old 09-12-2009, 05:33 PM
bad6as's Avatar
for a 347 on pump gas w/o meth in a car that has a race weight of 3200 and 150mph trap speed goals what turbo would i need
Old 09-12-2009, 05:41 PM
Snyper's Avatar
My goal is 150mph traps too..pretty much same setup just with the 364ci.
Old 09-12-2009, 06:05 PM
abbaskhan's Avatar
try a 80mm from comp turbo triple ball bering!!
Old 09-13-2009, 11:30 AM
subarubill96's Avatar
id use the TC-78 if space is super tight, thats what im going with but im just looking for 9.99 at 135-140 MPH.
how much does your 350 weigh in comparison to an Fbody? i imagine a bit lighter but ive been wrong before.
Old 09-13-2009, 05:13 PM
b005td's Avatar
or a GTM-78 from dr turbo ? its a Tc78 with race cover
Old 09-14-2009, 09:33 AM
LS1TECH Sponsor
DrTurbo's Avatar
Correct the GTM78 is a bad ****.
Old 09-14-2009, 11:43 AM
Snyper's Avatar
The car as it sits with 3/4 tank of gas and no spare or A/C is exactly 3100lbs(+-20lbs)
Can you get the PT78 in anything bigger than a .96 backside? Im looking for a slightly laggy turbo....
Old 09-14-2009, 03:24 PM
that thing is going to fly with a little more weight reduction and some moderate boost. id love to check it out if your ever around here at a car show or hanging out.
Old 09-14-2009, 03:55 PM
LS1Tech Sponsor
I would opt for a t6 unit if 150mph is your goal. It will work much better for you in the long run. Call FI and talk it over with them and order accordingly!
Old 09-14-2009, 06:23 PM
LS1TECH Sponsor
DrTurbo's Avatar
Agreed....a GT80 would be pimp. Make huge power and lag just enough to get the car hooked up.
Old 09-15-2009, 02:28 AM
Snyper's Avatar
Im also looking at the PT88..it seems like it MIGHT be what im looking for as well..any thoughts? Once I take my front end off ill see JUST how much room I have..but I think i might be able to fit it forward facing off the passenger side.
Old 09-15-2009, 02:44 PM
LS1Tech Sponsor
I think you will be really happy with that unit, should be rock solid.
Quick Reply: TC78 or PTE78 for LS2?
