Oil pressure gauge
Old 09-11-2009, 04:53 PM
Blue92coupe's Avatar
Default Oil pressure gauge
Is it ok to T off the turbo feed line for an oil pressure gauge? And im not running a gauge cluster so could I just remove the factory sender and use that port or does the computer need a signal from the factory sensor?
Old 09-11-2009, 10:16 PM
jomomma's Avatar
i believe the pcm needs to see oil presure. i have tee`d off my feed line for a pressure gauge. its not like the oil is going anywhere on the gauge side. it will still feed the turbo adequatly.
Old 09-12-2009, 12:24 PM
ok thanks I appreciate it, any other input?????????
Old 09-12-2009, 05:27 PM
bad6as's Avatar
pcm does not need to see oil psi. friends ls1 notch does not have a way to read oil psi, but now hes rebuilding it because of some spun bearrings.
Old 09-12-2009, 06:13 PM
great I would rather not T off the turbo feed line!
Old 09-12-2009, 10:53 PM
jomomma's Avatar
did he not wire it in?
Old 09-13-2009, 10:13 PM
bad6as's Avatar
.yea.
Old 09-13-2009, 10:15 PM
jomomma's Avatar
yeah.... probably should have wired it in............
Old 09-13-2009, 11:13 PM
black98ws6ta's Avatar
The pcm does not need it an oil pressure signal. I would just break the factory oil pressure sensor and tap the inside of it with 1/8 npt, and put it there.
Old 09-14-2009, 02:57 AM
great thanks for the comments, I ordered an autometer adapter for 7 bucks that fits right where the factory sensor was. I feel better about that then stealing oil from the turbo at startup.
Quick Reply: Oil pressure gauge
