BOV @ Idle ??
BOV @ Idle ??
Ok, so I read ALOT of conflicting info on this subject.....
On a Turbo car, should the BOV be open at all at a base idle?
At first I assumed it would stay shut at idle and crack just during decel, but I also see alot of guys say that at idle it should be open and air blowing out? One or the other must not be set up correctly...
Keep in mind this is a Turbo application....
What are the FACTS?
What are the FACTS?
i would also like to know, and being that im running a 2 bar SD tune, i cant start my car to test any of this stuff i took a mity-vac and put it on the BOV and adjusted it so it starts to open at 15" which is what my motor idles at. hopefully that will get me close enough for dyno time
At idle you'll be in vacuum so there should be no air blowing out of it. It should be open and sucking in.when you hit boost it will push the bov closed and pressurize your intake piping, then when you let off the vaccum in your vaccum line sucks it open and relievs pressure.
Depends on the setup....if the BOV is after the air meter sensor, the bov will have to be closed at isle otherwise unmetered air is being let out of the charge pipes with the bov being open at idle, causing a rich condition, idle surge and will probably stall out.
if the bov is before the air meter sensor, it doesn't matter because what ever has escaped the charge pipe with the open bov is not taken into account until it gets to the air meter...so the ECU compensates for it
the lighter the spring the better reaction time it will have, blower guys need it open at idle (and part throttle cruising) to avoid pumping losses and making positive pressure at idle
SO...I still see contradicting answers here...some say closed some say open. I could see especially on a Procharged setup it needing to be open due to such positive displacement of the charger...but at idle does a Turbo move enough air that it needs to be released by the BOV?
Maybe a sponsor that builds turbo applications often could chime in?....
Interesting observation...
Thats what I was wondering since technically some guys have even gone without a BOV (I wouldnt, but I know its been done)...
So Im starting to assume it will WORK either way....but maybe a certain way is better?....There are obviously guys running open and closed both...
This seems way harder than it has to be...LOL
8 sec potential, 12 sec slip
I was always under the impression a BOV is supposed to be closed at all times except when it sees a sudden surge of backpressure, then it is supposed to open to release the air built up in the system on decel. A BOV is for turbo applications for this reason that turbos won't create positive pressure at lower (idle) speeds.
A BPV is supposed to be open at all times unless under boost to allow the system to pressurize, and then open once the throttle is let up which causes the system to go back into vacuum. This is for supercharged cars primarily, but can be used for turbo cars as well.
if air meter is before the bov - bov needs to be closed at idle
if air meter is after the bov - it doesn't matter
one is not better than the other as long as the BOV is functioning
It will be irrelevant on my car as far as the metered air as I will be tuned in SD...
You need to keep in mind vacuum is what keeps the valve open (sucking) and it shuts when positive is applied. Another way to test it is disconnect the vacuum hose going to the blow-off valve and watch it shut. Thats why you see alot, if not all, running a MAF they have the blowoff valve before the MAF.
On a MAF tune, it really shouldnt matter if its sucking air in thru the BOV/ BPV or blowing excess air out, the point is, the metered air that has gone thru the MAF will not be the same as whats going into the engine as expected by the computer if the valve is after the MAF. So just to keep things on par, if you are running a MAF tune, put the valve BEFORE the MAF measures it.
And BTW, I don't really see any way of air being drawn IN to the intake tract thru a BOV or BPV, it should be spewing excess air OUT of it..
