STS guys with Meth in here please?
Old 09-19-2009, 01:00 PM
vipvegas's Avatar
Default STS guys with Meth in here please?
Im using the sts piping and going to install a stg 2 snow kit. My question is is on the first pipe coming off the intake the AIR temp sensor is plugged in the pipe. Where are you guys injecting the meth, I thought you want to be before the sensor so it can monitor true? But I also thought you wanted it as close to TB as possible. Any pics or insight on your setup would be appreciated.
Old 09-19-2009, 02:09 PM
sujomatt's Avatar
i have mine just a little closer to the TB then the IAT sensor (maybe a half inch or 1 inch) on the opposite side of the pipe.
Old 09-19-2009, 09:28 PM
vipvegas's Avatar
I really dont want to put it in the bend right above the MAF and right below the IAT so I guess the only way is put it closer to intake elbow and move the IAT then plug existing IAT hole. WHat you think? Also how far away from the sensor does the nozzle need to be?
