What might be the problem w/my #4 cyl and the spark plug???
Old 09-29-2009, 12:32 AM
oufan2929's Avatar
Default What might be the problem w/my #4 cyl and the spark plug???
Some people call it the shoulder strap, wikipedia calls it the side electrode. Anyways, what are some options when the side electrode bends over and touches the center electrode. Basically closing the gap. It's got a tiny nick on the side of the electrode as if something hit it. Car was running funny, then put a new spark plug in and it's running like a champ again. Checked the compression and it's perfectly fine. It's done this twice. The first time I was hoping for a fluke, but it's done it again, so now I'm counting my blessings I didn't hurt anything. What are some possibilities from you FI experts. Oh, and it's got a paxton on it making about 15lbs. of boost. Thanks!--Andy
Old 09-29-2009, 02:27 AM
crashly's Avatar
its called a piston.....
Old 09-29-2009, 07:56 AM
SilverSS's Avatar
simple as that. that piston wants out.
Old 09-29-2009, 08:12 AM
dschmittie1's Avatar
You might want to try indexing the plugs to help prevent that from happening.
Old 09-29-2009, 08:37 AM
Restricted User
98Z28CobraKiller's Avatar
Pull the motor and check it before it really lets go. I have had that happen to 2 motors and both times I wasted the block by not taking it apart. This is NEVER EVER a good thing.
Old 09-29-2009, 10:16 AM
oufan2929's Avatar
can someone expand on this brilliant observation? what causes the piston to be able to reach the electrode?
Old 09-29-2009, 10:27 AM
Fireball's Avatar
if you're running a stock shortblock at 15 psi...it means you probably are quickly running out of borrowed time
Old 09-29-2009, 11:45 AM
oufan2929's Avatar
Built bottom end...I'm wondering if the machine work was done improperly...
Old 09-29-2009, 11:48 AM
Fireball's Avatar
wonder what your effective deck height is.
but the fact that it doesn't happen all the time makes me think something is stretching which is a sign its about to go *poof*
Old 09-29-2009, 12:08 PM
Shawn @ VA Speed's Avatar
the heads would have to be milled excessively for a piston to hit the plug.I'm leaning more toward detonation-can you post up pictures of the plug
Old 09-29-2009, 12:19 PM
oufan2929's Avatar
Unfortunately I regapped the plug. So I don't have a pic of what it looked like. Could it be a main bearing gone to crap?
Old 09-29-2009, 12:37 PM
'Trust''s Avatar
On the yellow car? Could be detonation, throw some 101 in there and see what it does for awhile.
Old 09-29-2009, 01:40 PM
Restricted User
I vote to take it apart or atleast get a bore scope in the hole soon.
Old 09-29-2009, 07:37 PM
Dean95z28's Avatar
I agree with this guy!!! You need to get a bore scope in there to at least see if it is the piston hitting the plug.
Old 09-29-2009, 07:45 PM
Restricted User
May have busted a ring land.
Old 09-29-2009, 08:01 PM
oufan2929's Avatar
There's a few nicks on the top of the piston, about where it'd hit the spark plug. Compression is still good though. My latest thought is worn out rod bearing?
Old 09-30-2009, 12:33 AM
crashly's Avatar
piston rocking in the bore : wrong piston clearance or wrong pistons
big end bearing wear or wrong clearances
cylinder head machined excessively , too much taken off
block machined excessively, wrongly set up in mill
wrong spark plug reach or type of plug, there is a 3/4 reach and shorter...plus projected plugs , and non projected...
it that a brilliant answer or what ???
Old 09-30-2009, 07:47 AM
oufan2929's Avatar
Just what I was looking for crashly thanks.
Now, if the heads or block were milled excessively, would I not be hitting other spark plugs?
Could it be just as simple as buying a shorter spark plug? None of the other plugs the same length hit...
I was told by a very informative guy that he thingks its the rod bearing which makes sense. Allowing it to stretch a little at high rpms. Thoughts???
Old 10-01-2009, 02:11 AM
John at J&S's Avatar
How could the piston hit the side of the electrode?
Do a leak down on that cylinder. Sounds like there was something flying around in there.
Old 10-04-2009, 04:03 AM
oufan2929's Avatar
So would adding a washer to the spark plug be asking for a blown motor? My shop is wanting to do that to "see if it fixes it"...
Quick Reply: What might be the problem w/my #4 cyl and the spark plug???
