No Boost - Turbo
Old 10-12-2009, 07:41 PM
JerikSS's Avatar
Default No Boost - Turbo
My car is only making 3psi on a 7lb wastegate spring. We have checks all vacuum lines and checked for exhaust leaks and nothing. The turbo will not boost more than 3 psi. Its a single front mount turbo kit. I used OFI's hot parts. What could it be? Its currently at the dyno and would really like to get this thing to 7psi...
Old 10-12-2009, 08:24 PM
JerikSS's Avatar
i really really need help with this im lost...
Old 10-12-2009, 09:17 PM
TXZ0603's Avatar
sounds like a wastegate problem. Double check your vacuum line to the gate and check the gate so that its seal is good. make sure its not leaking from the side when you changed springs
Old 10-12-2009, 09:23 PM
cablebandit's Avatar
i have a 9psi spring and thats what my ofi kit makes. Make sure you dont have a very restrictive air filter and/or exhaust
Old 10-12-2009, 09:27 PM
JerikSS's Avatar
I have checked my wastegate and it looks good, I have a huge air filter, the exhaust is good. My head hurts from this thing. I am so
Old 10-12-2009, 10:03 PM
The Fugitive's Avatar
Did you check you wastegate diaphragm, that is a common issue. But if you are not making pressure that you should with no leaks anywhere you should try the IC and while you're at it check the turbo make sure all the seals and gaskets are good.
Old 10-13-2009, 03:03 AM
rocket5979's Avatar
Out of all of the cases I have seen where people were encountering over or underboosting situations they were almost always directly attributed to wastegate or BOV issues, whether that be the part itself or improper installation if boost/vac lines going to it. Even doing a free-rev while looking at the BOV will indicate if it is at least somewhat working properly. Recheck it all and if you still have problems then cap both ends of the cold-side and do a pressure test of the system. Chances are likely that it is something simple that was just overlooked.
Old 10-19-2009, 08:35 PM
JerikSS's Avatar
triple checked everything and nothing still no boost????????????
Old 10-19-2009, 08:39 PM
rocket5979's Avatar
Did you pressure test the system? Did you doublecheck your WG spring to make sure it was the correctly rated one? Check for potential exhaust leaks?
Which exact turbo do you have? What are the full specs on it?
Old 10-19-2009, 09:03 PM
98Camarod's Avatar
Stuck open gate or bov?
Old 10-19-2009, 09:14 PM
needaz28's Avatar
what kind of gate are you using? I had the same problem with my jgs 50mm. turns out it was my "7psi" spring was not enough. I went with a double spring set-up and now I'm making 6.5-7 on gate.
Old 10-19-2009, 10:04 PM
Johnv's Avatar
If your exhaust system is restrictive it can cause issues makeing spring pressure rated boost due to back pressure.
have seen a setup need 16psi worth of spring to make 8 psi boost, went from a 3" to 3 1/2" exhaust and instantly would make 16psi boost (no other changes)
Also if your boost reference is from the turbo and you have a restrictive intercooler/intake you won't see wastegate spring rated boost at manifold, move the wastegate boost ref to manifold and you will.
Old 10-19-2009, 11:47 PM
so if you have an intercooler you want to run your wastegate ref to the manifold? I thought about that but most diagrams that I see don't have that.
Old 10-20-2009, 02:59 AM
Johnv's Avatar
If you have a 7lb spring and want to see 7 psi at the manifold, reference the gate at the manifold. If you ref at the turbo there will be some pressure drop between turbo and maifold due to intercooler and intake pipes.
Old 10-20-2009, 07:23 AM
needaz28's Avatar
mine would make 2.5-3 psi, my dp ends about 6-8 inches after it goes through the k-member. after talking with the guy who designed the wastegate (very nice guy from jgs) he explanied that there using the same springs as that from a very well known and trusted wastegate company. that company rates there springs off the back pressure most 4cly. produce. when you get into the bigger cibes engines all that changes. thats why the big boys dont even mess around with changing springs all the damn time, they just run co2 to control everything. at first I thought he was just trying to sell me some 20 dollar spring, he sent out 2 different springs for me to try. (think I paid $12 with shipping for them). tried the "big" spring and the car would lag, then just jump to 10+psi. put in the "med." spring and the one I already had car now makes 6.5-7 psi by 3000 or so. jgs gates are made so you can run 2 springs if you wish/need.
I'm running a mp76 with a q trim, I vac. ref. right off the turbo housing to the wastegate (about 4-5 inches away from each other).
op have you tried pressure testing your cold side?
Old 10-21-2009, 01:03 AM
Restricted User
rodscars's Avatar
If you grab the shaft of the turbo does it seem to spin freely? Also if the "budget kit" comes with a tial 44mm gate, then perhaps you did not install the fire ring. Hope that helps good luck and it'll be interesting to see what the problem is.
Old 10-23-2009, 09:21 PM
JerikSS's Avatar
Im going to change the vacuum source to the intake. The spring is fine, and everything else is correct. Im crossing my fingers for this.
Old 10-24-2009, 04:13 AM
devilssled's Avatar
any luck?
Quick Reply: No Boost - Turbo
