Quick connect tubing
I am using quick connect fittings and tubing. I keep melting this black tubing causing my boost to always go crazy. Last time I drove my car it was making 12-13psi on the spring. I get in it today and it is at 15psi. On the way home it spiked to 22psi. I took it easy the rest of the way. My question is does anyone else use this tubing? I am going to replace it and put some rubber hose around it to protect it from heat off of the uppipe but do you think that the heat from the compressed air is what could be causing this also?
The problem
The consequence
No leaks from it(radiator that is).
The problem
The consequence
My tig machine will be here monday, the pipe is to short going to the TB. It was trimmed to fit the FAST and is now a little short for where the TB is.
I'm not trying to be cheap, I thought I was using the good ****.
personally, id use as much hardline as possible then use either silicone or rubber vacuum line hose and see what it gets you. i use that plastic quick connect stuff on pnuematic controls and it holds up just fine until it gets stupid hot as you have unforunately found.
Good Silicone vacuum hose will work just fine. Rubber is no good with high heat applications so don't even bother. It will burn and crack and cause serious issues with your setup.
Those lines that you are using are not intended for this kind of use, so get rid of them asap before you break stuff.
Most small diameter silicon hose is ****. I'd use rubber well before I'd even consider silicon.
Although if you insisted on hardline nylon tubing, at least route it away from heat, and avoid any bends on the hose.
Although if its a wastegate you used it on..considering its attached to an exhaust which gets kinda hot...using cheap nylon tubing isnt too bright. Obviously its going to melt. At the compressor end where you picture it should be fine though. But why isnt there a 90deg fitting there ? That pipe has kinked because its all been fitted badly just ?
you arent getting what Im saying.
A 90deg where the pipe has buckled., or as you say a straight on the comprssor housing.
Just go and buy some, they are very cheap, as is the pipe itself.
Oh I was talking about the fitting coming out of the compressor housing is a 90 and I need a strait. I replaced the piece with a longer one that made a smoother bend. I beat on the car hard last night running around 15 races and the tubing is still fine but I will replace it anyway with better stuff here shortly.
