master power turbo question
Old 10-16-2009, 07:39 PM
awd-rwd racer's Avatar
Default master power turbo question
im looking at a used master power t-76 turbo. i have a stock ls1 with basic mods. looking to do a basic turbo kit. looking for around 5-550rwhp. is this turbo ok? will it spool too fast? it has a t3 housing. ill be reving to 6200 for the time being. also there are pics a few posts down, can you tell if its a t4 or a t3?
here are the specs
Master Power T-76 P-Trim Series
Rated up to 800 HP
Compressor Wheel Compressor Housing
Inducer dia. Exducer dia. Trim A/R Air Inlet
76.5mm 103.5mm 55 .72 101.5mm
Turbine Wheel Turbine Housing
Exducer dia. Inducer dia. Trim A/R Div/Undiv. Discharge Inlet Part Number
64.5mm 74.0mm 76 .96 Undivided V-Band T3 810047-396
Old 10-16-2009, 09:34 PM
xXxSilveradoxXx's Avatar
That turbo is fine. Also, there is no such thing as a turbo spooling too fast!
Old 10-16-2009, 10:03 PM
lol....i dont get too much traction in 1st and 2nd as it is now being n/a. so it would be nice to have a little lag.....geeze never thought i would say that..haha
Old 10-16-2009, 11:20 PM
highflyin's Avatar
The master power turbos are really not that expensive new and come with a waranty. Unless your getting it really cheap i would suggest you just buy new.
Old 10-16-2009, 11:58 PM
Johnv's Avatar
You sure its not a .96AR T4 exhaust housing ?
Old 10-17-2009, 12:42 AM
honestly im not sure.....is there a way to tell? i have some pics if it will help you tell..i live in pa. the turbo is in tx...lol
Old 10-17-2009, 12:50 AM
Matt97Ta's Avatar
post a pic of the inlet flange on the turbine side.
Old 10-17-2009, 12:51 AM
Old 10-17-2009, 01:07 AM
LS1Silverado05's Avatar
I think that might be a T4 .96 (The hot side should have it marked as far as A/R)
I have a MP T70 on my Stock (other than springs/pushrods/Injectors) 98 SS and even from a dead idle punch, it lags for a sec, but...when the turbo comes in....traction is gone...period.... so I would just plan on dealing with traction issues... I would'nt try to get a laggy turbo by any means!
Old 10-17-2009, 08:16 AM
MUSTANGBRKR02's Avatar
If you are worried about traction then invest in suspension and tires. The T70's are a great turbo to get you into FI for a budget build.
Old 10-17-2009, 08:22 AM
i have a good suspension. i just need wider tires/rims
Old 10-17-2009, 08:44 AM
TARZAN's Avatar
Originally Posted by awd-rwd racer
i have a good suspension. i just need some sticky tires
Fixed.
-Will
Old 10-17-2009, 03:31 PM
Sounds like a traction problem and not a turbo/lag problem!
That is not an adequate air filter.
Old 10-17-2009, 05:03 PM
i know...the turbo was on a drag only car...not a dd car....
Old 10-17-2009, 05:11 PM
1slo_camaro's Avatar
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
Hey get ahold of Rob at ModularTubo, hes a sponsor here on LS1tech and his number is in my sig. hes really good with Master Power
Old 10-17-2009, 05:27 PM
JAX04's Avatar
looks like a t4 .96 to me
Old 10-17-2009, 11:03 PM
kbracing96's Avatar
Ya, that's a standard MP T76, P-trim, T4 .96a/r turbo. FYI, those are about $775 brand new with 1 year warranty.
I ran one on my LS1 in my truck and they are a good fit for these motors.
Old 10-17-2009, 11:30 PM
TheFallen's Avatar
as previously noted that isnt a good setup. Ive personally seen a gain of 24 rwhp by removing the screen on the dyno. Ive tested a larger K&N cone filter vs no filter and only seen a 5 hp loss
Old 10-18-2009, 12:01 AM
transamfreak01's Avatar
yeah but i wouldnt take the chance. just like descreening the maf. no way. but yeah the 76 will be fine. you dont need a wider tire for stock purposes though? what type of tire is on the car? i would run m/t's and never look back. i think nittos suck the big one
Old 10-18-2009, 12:26 AM
Originally Posted by transamfreak01
yeah but i wouldnt take the chance. just like descreening the maf. no way...
There is no problem descreening the MAF, the newer MAFs don't have screens and they work just fine.
Quick Reply: master power turbo question
