aluminum block power potential
i have this in the gen 3 section also but it may be better here. r any of u turbo guys still using ls1 aluminum block on ur high hp turbo builds? i dont want the weight of an iron block and i dont want to spend 3500 on an lsx block after machine work. my goal is a daily driven 700hp with the potential to crank it to around 1100hp for some major decimation. i want to use something like a garrett gt55r so id assume boost pressure would be around 25lbs. any help would be greatly appreciated, i know a lot of u guys are putting down this kind of power, just want to see if its possible with a stock block
an ls2 aluminum block wil easily hold up to 1500hp with minor modifications.main cap walk and head gaskets are the 2 issues-i have fixes for both-let me know if you need any help
700 was my dd goal with the option to hit around 1100 whp. was just making sure couldnt really find any write ups on it and everybody says u cant but i could see no reason it wouldnt. and thanks shawn ill pm u
