Holy Fing trans brake!!! FLT 4L65E, tc78 KYTP KIT!
Old 10-21-2009, 07:28 PM
SPRAYED 01's Avatar
Default Holy Fing trans brake!!! FLT 4L65E, tc78 KYTP KIT!
So i just wiring up and tested my new rossler t-brake using a flt level 7 4l65e.
All i can say is Holy ****. Im also using a 2 step that i had set at 4k. I just tested it for the first time on the street. In a few seconds its at 11lbs of boost and destroyes the tires.
Im heading out to the track this sunday for the first time on a t-brake. Before i could only foot brake it to 2k and launch on 10 inches of vacum and was having trouble with my 60 ft (1.7). It went 10.6 that way at 130mph.
Hoping for bottom tens with this new trans setup.
To be honest im alittle freaked out on how crazy this thing is going to launch.
Any advise from you veteran t-brake users would be great.
Alex
Old 10-21-2009, 08:23 PM
dragcamaro's Avatar
videos???
Old 10-21-2009, 10:14 PM
SPRAYED 01's Avatar
It was just some street action for a few minutes,wasnt really worth a video. The track this sunday will be on video and on high res picture.
Old 10-21-2009, 10:26 PM
6 Second Club Moderator
LASTLS1's Avatar
Trans brake and tire spin on the street is no good! It's really bad for the trans. I would start off at 3500 rpm and gp up from there.
Old 10-21-2009, 10:29 PM
SPRAYED 01's Avatar
I let out right away, just trying to set up the correct rpm and boost levels before i go to the track.
By the way, how is it bad exactly for the trans?
Old 10-21-2009, 10:36 PM
blk96406's Avatar
Default track
Definitely post up some video!!!
What track??
Old 10-21-2009, 10:38 PM
SPRAYED 01's Avatar
Byron raceway in Byron Ill
Old 10-21-2009, 10:40 PM
pwrtrip75's Avatar
I'll be there sunday as well. No t-brake though. Wow....our cars are kinda similar.
Old 10-21-2009, 10:43 PM
blk96406's Avatar
Default Byron
I just might have to take a ride down- Im up in Madison
Old 10-21-2009, 11:07 PM
02SSLE's Avatar
I would leave off of one or the other not both until I got used to it. Makes a big difference the transbrake is your friend. I have a couple of video's of my old car with a tbrake.
leaving off 1 psi.
Leaving off the floor at about 8psi
Old 10-21-2009, 11:15 PM
73 nova guy's Avatar
hehe 8psi looks like a top fuel dragster blowing the tires off!
Old 10-21-2009, 11:17 PM
dragcamaro's Avatar
i just wanted to hear a ls1 with a 2 step, sounds so pissed haha
Old 10-21-2009, 11:19 PM
+badss+'s Avatar
hmm maybe too much boost just blowing up tires what rpm and boost leaving at
Old 10-22-2009, 03:14 AM
xXxSilveradoxXx's Avatar
I would think that the tires hooking would be harder on the trans than just smoking the tires. Although I'm no expert by any stretch of the imagination.
OP, The last three sentences in your sig are WIN!
Old 10-22-2009, 04:13 AM
crashly's Avatar
Alex
yeep,
rev it up and let the button go....
Old 10-22-2009, 05:49 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I give that poor 4L65E about a month to live with a transbrake and 2-step workign against it.
Old 10-22-2009, 07:45 AM
SPRAYED 01's Avatar
I have to have faith in the FLT trans. The guys there are top notch builders and they have loaded my trans up with all the best parts. Both input and output shafts are billet, and i run this thing really cool all the time. Never been past 180 with it.
Also i dont think it would be a matter of time when this trans breaks, id say a matter of how many runs.
Alex
Old 10-22-2009, 09:02 AM
02SSLE's Avatar
I think it will take one or the other not both. My car above was a 4 L80 conversion.
Old 10-22-2009, 09:36 AM
SPRAYED 01's Avatar
02SSLE, I thought it would be safer to use with the 2 step so it limits my rpm to what i set it to. I kinda newb at the t-brake stuff. Why do you say to just use the t-brake?
Alex
Old 10-22-2009, 09:52 AM
02SSLE's Avatar
Mine built boost pretty fast. I would just get used to one before doing both. JMO Because you will make boost really fast on both. Unless you have good tires and suspension then you are going to spin like video above.
Quick Reply: Holy Fing trans brake!!! FLT 4L65E, tc78 KYTP KIT!
