What are the big #'s being made with truck manifolds?
Old 10-22-2009, 08:38 AM
Gforce Engineering's Avatar
Default What are the big #'s being made with truck manifolds?
This whole truck exhaust manifold thing really has me intrigued.
I've read about guys making 800-900 and a little over 1000 hp with the truck manifolds.
Just wondering what the most power people have made with them.
Has anyone switched from truck manifolds to custom built headers after making big power with the truck manifolds to see what kind of power increase there was?
I'm slowly building my turbo set-up with a billet 94mm and I'm down to header fabbing.
Building headers isnt that big of a deal but if the truck manifolds will work then why not use them.
I'm looking for around 1300 rwhp from this build.
Thanks
Chris
Old 10-22-2009, 08:58 AM
02SSLE's Avatar
I think the Ohio Boys are using 6.0 manifolds making 2000 HP or close.
Old 10-22-2009, 09:32 AM
1320's Avatar
Mike Brown went 202 mph.......at around 3600lbs..
Old 10-22-2009, 09:39 AM
Wow, those are impressive #'s on truck manifolds.. keep em coming
Old 10-22-2009, 09:57 AM
tim99ws6's Avatar
Mike Browns car is 6.0
Mark Kohler's car is 6.0
both are well in excess of 1750rwhp and 200mph capable cars. That's about all that needs to be said in terms of "do 6.0 manifolds work". hahaha
Old 10-22-2009, 10:45 AM
427's Avatar
I think Mark is the only one that has been on a chassis roll with his "Ohio boys" car. He made 1300hp with his 6 litre engine last year in full boost mode, this year he ran a 1000hp average on 15psi.
Kurt
Old 10-22-2009, 11:23 AM
tim99ws6's Avatar
Kurt
Doesn't he kick around in the upper 20's with the current motor you helped him with?
I think i need to talk to you about your distributor setup...hahaha
Old 10-22-2009, 11:29 AM
427's Avatar
He is running a little over 30psi in his quarter mile runs. He would run more if he could, but he is out of turbo and the MLS head gaskets are crying now!We will be upgrading a few things this year when it comes back for freshen up, but the basic combo will stay intact.
Kurt
Old 10-22-2009, 11:35 AM
2001WS6Vert's Avatar
I think Mark was the last car to go on the dyno challenge and he just had to top high 700 rwhp range to win. That's why he only went to 15 lbs. I see all these cars with tubular headers that only gets bottle necked with the relatively small T6 turbo entrance. That to me + the heat holding of cast pieces seem to me to be the reason that they don't seem to do any better than the truck manifold setup, my .02.
Old 10-22-2009, 12:40 PM
Shearer's Avatar
Truck manifolds work and are capable of sustaining quite a bit of power. However there are gains to be had by switching to a proper tubular set-up.
Old 10-22-2009, 01:08 PM
Tiago's Avatar
700 rwhp won the dyno challange? wtf....
Old 10-22-2009, 02:09 PM
That was where it was at until Mark pulled 990 rwhp to win it. He obviously could have put more down but I guess didn't want to stress the car?
Old 10-22-2009, 03:29 PM
So it sounds like 1300-1500 hp wont be a problem.
Thanks for the input guys!
Chris
Old 10-22-2009, 04:49 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
867rwhp, 25psi, lil old tired 8:1 348 cid
Old 10-22-2009, 04:55 PM
86cutlass350's Avatar
my question is what are they doing just blocking off the egr port on the one side or?
Old 10-22-2009, 05:05 PM
Tally TransAm's Avatar
the ones i have dont have any emissions ports
Old 10-22-2009, 05:10 PM
tim99ws6's Avatar
Same here, mine have no ports. Just gotta get the right ones 86Cutlass.
Old 10-22-2009, 05:30 PM
chasgiv3's Avatar
882RWHP on an LQ4 block 408CI at 19PSI through a TH400 with a 4000 stall.
Old 10-22-2009, 05:48 PM
7 Second Club
BlwnTA's Avatar
I don't think we really know where the limit is yet. I'm making around 1850-1900bhp and Mike Brown is closer to 2000bhp or maybe more. As far as I know, we are only ones that pushed them that far and trust me, they will be pushed even harder next year .
Mark
Old 10-22-2009, 06:35 PM
You guys have supplied some great info in this thread!
Thanks
Chris
Quick Reply: What are the big #'s being made with truck manifolds?
