Here is a couple of dyno video's from a car that I just helped a friend build!
This is a car that a friend of mine (Aurthur) wanted to build on a budget.
Quick rundown of the setup: motor is a LS3 370 w/TFS 235's heads, F1 procharger, EPP fmic, Trans is a 4L80 w/PY3400, Strange 12bolt/3:73's. Mike at G-Force did the tune for him.
Tuning:
http://www.youtube.com/watch?v=agd46J9iJOs
Final dyno pull:
http://www.youtube.com/watch?v=H4UsR...eature=related
It made 776rwhp lost the TQ reading 18lbs of boost.
Previous run it made 759 on 18* of timing and 17lbs of boost. Tightened the belt a little as it appeard to be slipping a little up top as we hadn't retightened it since the original cranking of the car etc...
Jeff
Tuning:
Final dyno pull:
Jeff
Thanks the CR is 8.8-8.9:1 and it was on 93 octane (Pump gas for us in Texas.) only. It was on a budget not for free LOL! I mean he shopped for the parts like he bought my used F1 and got the FMIC kit off of a member used/new etc... I built the fuel system and did the bracket modifications for the procharger etc...
Exotic Performance Plus Nice numbers for such low of an compression ratio. He'll have a lot of fun with it! Bob
Adam Connell Man through a 12bolt and 4l80 he's gotta be making close to 1000fwhp!
I said budget not free or even cheap but cheaper than 90% of the builds of this caliber. And if you look I posted that he bought my used Pro-charger and used IC kit don't have nearly 6K in the procharger setup. The heads and motor were all new so there is some money there, but you are not going to make this type of power reliably with out building a motor etc...
