Replacement for my Snow Performance Meth controller?
Old 10-26-2009, 09:26 AM
great421's Avatar
Default Replacement for my Snow Performance Meth controller?
All -
I've had the unfortunate experience of burning out two MAF-based Snow Performance controllers for my Meth kit / pump in the last 3 years.
When they fail, they go from providing a start point, a 100% point, and a smooth ramp between the two points, to a simple ON / OFF switch which bogs my engine when it gets too much Meth.
I've checked my pump's input voltage line, and (as suspected) my second controller from Snow has failed.
Do I have any other MAF-based controller options out there? I really don't want to spend another $200 on a Snow unit which is gonna' fail (again!), but I will if it's my only MAF-based option.
Thanks - MIKE
Old 10-26-2009, 10:28 AM
ninetres's Avatar
Alkycontrol. Should have went with one the 1st time around.
Old 10-26-2009, 10:54 AM
vipvegas's Avatar
i have a devilsown and like it. But Julio at Alky is the man.. Top notch service, if I ever ditch this one he will be who I will go with. But my Devils own is nice.
Old 10-26-2009, 11:15 AM
JMitch19's Avatar
DevilsOwn also just came out with a new second gen unit that you can get with a built on map sensor or you can get it in a standard version. I really like their controller. It is a fully digital unit not analog like most I have seen.
Old 10-26-2009, 12:23 PM
KILLER-LS1's Avatar
check out painless wiring... they have a kit with a built in MAP sensor so you can control the rate in relation to boost. Thats whats going on my car
Old 10-26-2009, 07:36 PM
great421's Avatar
Thanks guys - but I'm looking for a Mass Air Flow (MAF) based system, so I don't need to do anything except replace the controller - does anyone (other than Snow) make this type?
LMK!
Old 10-26-2009, 09:43 PM
digitalsolo's Avatar
Talk to Julio, he has systems that work with a MAF for Ford. His customer service is top notch.
Quick Reply: Replacement for my Snow Performance Meth controller?
