5.3 turbo guys in here plz
Couple questions for ya
1) What cam are you running
2) what turbo? when do you get full boost (approx is fine)
3) what gears/tranny
4) whats your gas mileage like
Restricted User
1) What cam are you running 02 Z06 cam
2) what turbo? when do you get full boost (approx is fine) Master Power T70/.96AR most of the time around 4000-5500rpm, i can boost on the footbrake to about 5psi....
3) what gears/tranny 9" with 3.70 gears / stock 4l60E with vig 3600 soon to be t400 with brake
4) whats your gas mileage like if i stay out of it around 28 and 12 getting on it all the time
Also the turbo would spool alot faster but im blowing the 3600 stall to 5000+ rpm befor it grabs, lol.
check out my build thread in my sig.... also check out pwrtrip75 thread.....
I think you'll find alot of good info in the threads!
1)z06 cam
2)PT67 ~3500 or so
3)4L80E stock stall + 3.73 gears, stock 10 bolt w/ detroit tru-trak
4)~14 in town, its a d/d
Im currently running lean up top @ 5500+ but it still made 518rwhp and 496rwtq with hardly any timing + lean issue. my fuel should be resolved this weekend/early next week so ill have some final numbers with the final tune out soon.
-mike g
2)PT67 ~3500 or so
-mike g
made 528hp 491tq.... with power dropping like a rock at 5500ish.... once i get that figured out i think it will push 600hp!
