Is it safe to use stock IAT sensor? Can it react fast enough?
Old 10-28-2009, 06:10 AM
Vetal's Avatar
Default Is it safe to use stock IAT sensor? Can it react fast enough?
Main question is, can it react fast enough for turbo... Because I doubt they were designed to be able to change readings over 50F in a second, which could happen in a turbo car
Old 10-28-2009, 06:54 AM
Restricted User
98Z28CobraKiller's Avatar
It depends on where you place it. As long as you can get it away from a heat source and put it well in the air stream, should work fine. For instance, the factory location for a stock fbody car is a horrible place for an IAT.
Old 10-28-2009, 07:38 AM
Vetal's Avatar
I'm going to put it into charge pipe before TB. I didn't do it earlier because I thought that stock sensor can't be used with turbo because of slow response
Old 10-28-2009, 07:44 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Are you asking because of being able to sense meth? Or just for normal airstream?
Old 10-28-2009, 07:53 AM
Vetal's Avatar
Just air. Didn't think about meth, it's not popular here at all. Guess it's more of a tradition in USA.
Quick Reply: Is it safe to use stock IAT sensor? Can it react fast enough?
