A few questions on what size bov, wg, and intercooler for t76 street car?
Okay so I am going with a truck/c6 manifold build on my car. Stock internals, wont see more that about 8 psi. I plan on using an ebay intercooler, and was thinking a 31x12x4 would do? What size wastegate (probably 38 or 44mm) and what size blowoff valve i should use? I will either be using a t70 or t76. havent decided on meth or not yet.
edit: another thing i thought to ask was will i be okay on the stock radiator?
thanks in advanced,
Elliott
thanks in advanced,
Elliott
I would go with at least a 44mm. The bigger the gate the better boost control you will have. Being on a stock shorty I would want to make sure and keep the boost in check! The I/C will be fine at that size. I have a stock radiator in my car, just stood it up and I have had absolutely no heat issues in 90+ degree weather!
