Ok to run open DP for tuning?
Old 11-05-2009, 12:37 PM
XtremeDime's Avatar
Default Ok to run open DP for tuning?
I plan on running a TSP catback or something similar at some point but im wondering if running open DP when im tuned will somehow mess up the tune with a catback on it. Thanks
Old 11-05-2009, 12:42 PM
Photochop's Avatar
It will make better power with open downpipe. When the catback is on the car it usually tends to run more rich. You might consider a cutout when the catback goes on.
Old 11-05-2009, 05:13 PM
DeltaT's Avatar
And you must have a minimum of 18" of pipe after the O2 sensor or it will read very lean due to contamination with the outside air. If you are doing anything larger than a 3" pipe I would want min. 24" to get a good reading.
Jim
Old 11-05-2009, 06:13 PM
XtremeDime's Avatar
Im running the eBay turbo piping setup so the end of the piping provided is right before the axle, I dont think the o2 sensor will be a problem.
