434 with L-92 heads?
i am building a 434 lsx block, good internals . but i bougt a beck sheetmetal intake that was cut for L-92 heads. not sure if the heads will keep from lifting. i am using a F1-c probally around 18lbs. do you think the gm heads will work or is there some one else that makes any that style
this has been covered many times-over 800rwhp you are gambling with the l92's-more often than not,on the losing end.
Mast motorsprts is selling an aftermarket version of the l92's/ls3's.The are made by Cary at Performance Induction-so they are a VERY good head.
