Budget build info wanted
How many people do a DIY truck manifold kit and use A STOCK SHORTBLOCK? this means bone stock. lookin to put some 317's on my short block and then build the kit. question is how many people have done this? how long will it last? how much boost did u push to it?
I never got any numbers out of mine before I pulled the motor for my TSP 370 that will go in over the winter, but I was running 8psi on a T70 stock long block (other than springs and pushrods) while we played with it. Saw 12psi a couple times and never had any issue. We were being very safe with timing and fuel tho, thats obviously the key! Go for it!
My buddy made 500rwhp/500ft-lbs at 8.5-8.75psi with a 78mm turbo on an STS kit. Bone stock motor. Only thing they changed was to a 918 valve-spring and pushrods cause the stock springs were letting the valves float.
That was through a Ford AOD trans(no lock-up) and a 12-bolt.
Sell the ls1 longblock, buy two 5.3 longblocks and you have a spare. Throw in a z06 cam/springs/pushrods, and let it eat. Should be good 550rwhp or less for quite a while. Mine is just over 550rwhp through an auto and has been taking a hard beating this year in my car and maxxmitchell's car before mine, 140k mile junkyard longblock.
The biggest hands down way to make it survive is a GOOD tune.
