11.1 or 11.5 compression any good for boost???
Old 11-21-2009, 04:14 PM
99 Blue Bird's Avatar
Question 11.1 or 11.5 compression any good for boost???
im building a forged 370 iron block and want the compression around 11.1. my question is will a 11.1 motor be ok with 10-15 lbs of boost out of a turbo? not to familiar with the forced induction set ups. all i know is the lower the compression the more boost you can run. but im not tryin to run something crazy like 28 lbs or something. so any info would be great. thanks everyone.
99 Blue Bird is offline
Old 11-21-2009, 04:27 PM
The Fugitive's Avatar
what kind of car all drag DD etc? I would say try to get somewhere from 9.0 to 9.5 CR but we would need more info on your set-up and what it's being used for.
The Fugitive is offline
Old 11-21-2009, 06:00 PM
Z-28's Avatar
Sound like u might wanna run race gas for that setup
Z-28 is offline
Old 11-21-2009, 06:19 PM
robert miller's Avatar
Without more info I wouldnt want too go over or much over 12psi and put a D/nozzle of meth too the car.With a little less timing. then work up a little into it.
robert miller is offline
Old 11-21-2009, 08:14 PM
jason02Z's Avatar
sure lots of meth or if you can get a good fuel system and e85..
jason02Z is offline
Old 11-21-2009, 08:20 PM
G Engines's Avatar
IMO thats to much compression for boost I stay between 9.5 to 10.0 and run a meth set up on it.
G Engines is offline
Old 11-22-2009, 04:48 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=39
Here is an APS Firehawk we built that has an 11.0/1 engine. I agree with what everyone has posted, I would drop the compression ratio down into the 9.5/1 range. Bob
EPP is offline
Old 11-22-2009, 01:43 PM
the car is gonna be a street car. not really a dd but if i want to dive it i just want to jump in and go. since i live in california the only turbo set up i can use is the sts rear mount set up since it has a CARB legal #. the motor will be around 10.8 cr but when i mill the heads will bring it around 11.1-11.5 depending on how much i mill them. heads will be TEA cnc ported 243 castings or the PRC 215 castings. i will be using a tpis LS6 ported manifold as well. and will be keeping my exhaust manifolds on the car. will be ported. all smog parts hooked up as well.
Old 11-22-2009, 03:06 PM
okay so the big question would be is what is your HP goal? That would make the difference with how much boost you throw at the car. Plus if you are wanting to make some serious HP then I would say go with the 317's to lower compression.
Old 11-22-2009, 03:11 PM
383lt1impala's Avatar
u have to run really good fuel and have a really good tuner... i plan to run only 10psi with 12.5 compression. on c16
383lt1impala is offline
Old 11-22-2009, 04:23 PM
smokinHawk's Avatar
https://ls1tech.com/forums/forced-in...turbo-faq.html
smokinHawk is offline
Quick Reply: 11.1 or 11.5 compression any good for boost???
