Coupling intercooler piping question, V-band
For those you who use V-band clamps, do you experience any boost leaks?
I found some pictures of some high boost cars using V-band clamps to hold the piping together. I'm assuming these are the same clamps as used in exhaust apps. right? If so do you silicone them or use a gasket or not or what?
Wolfe makes some with o-rings. I am sure there are others who do as well.
http://www.wolferacecraft.com/vband.aspx
we also had vbands at the turbo outlet and the intercooler inlet and outlet ports.
I don't have any great pictures of the throttle body flange...
Restricted User
I would suggest always using O-rings on the aluminum coldside V-bands. Not always necessary, but they are cheap and will help seal even a warped flange.
Copper RTV on the hotside intead of O-rings.
