228/228 .588.588@113 good cam for my LS2/t88 turbo setup?
What do you guys think of these specs for my setup? Cars a 6 speed t88 LS2 looking to make around 850whp with this turbo.
228/228 .581/.581@113
my cam is almost exactly those specs. 228/228 .588 .588 115LSA, very little chop and gets the job done... but now I'm gonna put it to the test on the 370 with a front mount and auto vs the 346 and rear mount with a stick
As you will find with most things you post on here, the big experienced guys dont answer, ever, not sure why? If you want a real answer just call Shawn at Virgina Speed and tell him your setup and what your wanting to run, he can give you a straight answer on what will and wont work.
idle 850-875
rpm range-65-6800
compression around 8.8-9.0
fuel-80lbs injectors/twin 255s
front mount 88mm
...im actually looking for something that is pretty laggy and comes on strong in the upper rpms...now I just have to decide between 113&115lsa..any suggestions on that?
rpm range-65-6800
front mount 88mm
My end goal with this turbo/setup is to run 150mph in the 1/4. I already went 130mph on street radials making 503/509 so im hoping I can get there with this turbo.
