lq9 + s475
lq9 + s475
03 lq9 with ls6 cam, ls2 timing chain, hardened push rods and arp rod bolts.
Ill end up lowering compression when i forge the internals, but with the 10.0 to 1 compression this motor has, how much boost/power can be made withOUT meth injection?
....i do have an air to water intercooler, just not wanting do use meth injection right now.
Also using 93 octane for this setup.
And yes i have researched on here for a while, seen anywhere from 500rwhp to the 8xxrwhp goat...most use meth injection, just trying to see what others have done
Only really wanting about 550rwhp before the forged internals, which seems very doable, but maybe a 50 or 100 shot on top?
untill i get forged internals im wanting to stay at or below 8psi, but whatever gets me 500rwhp is where it will be set at, most likely have a 50 shot on the motor for further cooling and getting boost up on the line as well as a tenth or two down the track
s475, it an borg warner/airwerks s400 line of turbos...75mm with a 1.10 a/r
id say you could break 500 relatively easily, what heads are you running? stock bottom lq engines have made some great power, im pretty sure there are cars breaking 600 on stock bottoms, the rods are the weak part, im pretty sure there was a truck on here with a stock bottom lq4 that made like 7xx? it was a white sierra rcsb... mighta been a step side
that engine has less compression though if it was a lq4
anyway sorry about the rambling, i believe you can make 550 without meth, plus you have an air-water ic so it aughta help a little more over an A2A
correct me if im wrong im just going from memory
stock heads and stock truck intake
also, what boost are the ls6 yellow springs typically good for? They are brand new and not really wanting to take them out and put in dual springs untill the internals get upgraded
I know it will have atleast a 4 inch down pipe and 3inch tubing for the cold side...would that be adequate enough?
