FYI Truck Manifold Guys
Old 12-01-2009, 10:30 PM
Ping King's Avatar
Default FYI Truck Manifold Guys
Just test fit a passenger 98 f body manifold on the driver side, fit just like a truck manifold. The 98 F-body manifolds appear to be exact copies of the truck manifolds but in extruded stainless.
Just an FYI because these are stainless, it would be easy to weld a v band right to them without the complications of trying to weld to cast iron.
Old 12-02-2009, 08:35 AM
Steve-O's Avatar
??? does the driver side fit on the passenger side?
Old 12-02-2009, 09:45 AM
smokinHawk's Avatar
it doesnt put it in a good position on the passenger side.
Old 12-02-2009, 10:05 PM
Ping King's Avatar
Im going to test fit the pass side whenever i can get a change. The big plus on these are that a stainless pipe or v band can be easily welded to them.
Old 12-03-2009, 08:08 AM
Steve-O's Avatar
if so I dont see any real gains of doing one side and not being able to do the other side the same way... then you will still ahve two different metals on opposite sides...
Old 12-03-2009, 11:50 AM
jfg455's Avatar
we used a pass side F body manifold for the drivers side of the 99 mustang 6.0 T76 build we did. Welded a V band to it and crossed it over to the drivers side log. Plug and wrires all fit well and cleared the steering. Don't know about the P/S pump as I used the ford unit. it was smaller and had a remote res.
Old 12-03-2009, 06:44 PM
Ping King's Avatar
no different that having a log of stainless on one side and cast iron stock manifold on the other.
Old 12-03-2009, 06:58 PM
NemeSS's Avatar
yup. got mine with cast and ss manifolds
Old 01-01-2010, 03:51 PM
lazylongboarder's Avatar
I'm really interested in this for my conversion to put the turbos up by the valve covers.
ARE THERE ANY OTHER MANIFOLDS THAT ARE WELDABLE? Or just the 98 F-bodies?
Russ
Old 01-01-2010, 11:37 PM
Ping King's Avatar
Ive seen people weld v bands to a cast manifold. its much easier to just try with a 98 manifold which is almost identical to a truck manifold, but in extruded stainless.
Old 01-02-2010, 07:30 PM
eviltwin_1987's Avatar
how many times are you going to repeat that?
Old 01-02-2010, 07:39 PM
stevensLS1's Avatar
So far 2
Old 01-03-2010, 09:36 PM
Ping King's Avatar
x3 lol
just figured i would reiterate the difference between the stainless and cast.
Quick Reply: FYI Truck Manifold Guys
